Working on top ten lists: what do YOU want?
I want to consider everything you want to see in the lists. If you have ideas, speak up before I'm done!
Yer probably already on it, but...
Separate the electrics from the dino wine burners! |
I hope you guys like vbulleting because IT SUCKS for making anything custom.
You can do it!
Wow, I can't believe I was such an idiot and made such a stupid mistake for all these hours.
EcoModder Fleet list - EcoModder.com |
So it's separated into regular gas, diesel, and electric, right?
You should make a separate one for % over EPA to help point out that better drivers, not just efficient cars, can get good mileage also. |
Good job SVOboy :)
I'm with McTimson, % over EPA. You could make those in a table right under the mpg's (2 rows - % & mpg, 3 columns - gas, diesel & electric). |
I think something's not right. There's a car missing in the gas list. ;) Should be at #5.
Should hybrids be in their own category? |
The reason your car isn't up is because it's lifetime. I will switch it to 90 day since that makes more sense.
Also, will investigate if we're set up for hybrids and such. And do the % over stuff |
SVO - Will this be a constantly changing list as people update their fuel logs? That would be cool if it auto updated. I liked Piwoslaw's idea so you could sort the 3 types of cars (gas, hybrid, electric) my mpg and % over EPA.
