World's first hybrid - Porsche Semper Vivus
The 1900 Lohner Porsche Semper Vivus was the world's first gas-electric hybrid, with two 3.5hp electric hub motors. A later version had 4 hub motors, making it the first 4-wheel drive car. The 80 volt bank of 44 batteries weighed in at 1800kg and could not be charged from an external source (as in today's plug-in hybrids) but instead was charged with a rear mounted internal combustion engine. In 1898 Ferdinand Porsche (only 18 yo at the time) constructed an efficient electrical motor small enough to fit inside a wheel, and two years later built the Semper Vivus with Austrian carriage builder Ludwig Lohner & Co. Porsche Semper Vivus Hybrid - CarSession.com Lohner Porsche Semper Vivus Porsche Semper Vivus - Interia.pl |
:D Looks fun.
In the first picture, is that a brick wall where the radiator usually is?
Thats some pretty slick engineering right there.....
AND..... LMAO at this question: Quote:
Also, both pictures suggest that the engine is in the front, while the info I found stated that it was rear-mounted. I'm willing to bet that there were a few units built, each slightly different. The second, color picture is a restored version from this year's Geneva show. |
This is incredible how much this man was ahead his time...
Another page with 3 pictures : The 1899 Lohner Porsche, the first Hybrid Vehicle? Have fun, Denis. |
Bob Wilson |
More info in texanidiot25's thread.
Indeed, it's just the opposite: GM might not be able to validly patent certain parts of the Volt because Porsche had already done them, making it "prior art". |
This is not really a hybrid when only the electric motors power the wheels. It's the same principle behind diesel-electric train engines. Keep the combustion engine at a constant load where it works optimally in order to generate electrical power.
It's kinda like what the Volt was supposed to be. |
This *is* a series / serial hybrid; not a parallel hybrid. It really is a hybrid; just a different kind of hybrid than we are used to.
If there are batteries or capacitors involved, then it is a series / serial hybrid. In fact, it is the electricity that is the "transmission" between the genset and the electric drive motor, so that is a hybrid, too.
Two types of motors are involved in moving the vehicle = hybrid. |
Are you saying the torque converter makes automatic cars a hybrid? you would make the term completely meaningless. It is about storing/reusing braking energy, regardless of the conversion processes. Hybrid train - Wikipedia, the free encyclopedia "uses an onboard rechargeable energy storage system " Does it make sense now? |
Can an automatic transmission provide power?
Two (or more) types of motors = hybrid. |
Transmissions 101, a prep course... Quote:
Motors are motors, and transmissions are not motors. The transmission is not a power source.
By your definition, a Prius is not a hybrid -- where does the electricity in the battery come from? |
in part from regenerative braking, or from the wall.
If it did not recapture braking energy (or occasionally allow use of a wall socket), hybrids would get really crappy mileage with all that dead weight and complexity. Quote:
Edit- NVM, dumb mistake on my part
Power source is not the same thing as an energy source. And engine or a motor is a power source. Fuel or electricity is an energy source.
Two different types of power sources, combined in some fashion i.e. hybridized is the definition of a hybrid. In a standard Prius (not a plugin) even the regenerative braking energy came originally from the gasoline burned earlier. So, if your definition of a hybrid (two different energy sources) is correct, then how is a Prius a hybrid? The original Porsche was a series (aka serial) hybrid and all the energy in the batteries came from the engine. And a Prius is a parallel / series hybrid, since it can operate in EV (using energy put in the batter by the ICE and/or regen), ICE, and combined, too. |
Not doubting you rofl, but can you provide a link to what you are referring to?
It sounds like confirmation of the inefficiency of electric regen on the surface though (soaks up plenty of braking energy but doesn't return much of it). Either way, it is the rechargeable nature of the battery (or the accumulator) what makes a hybrid useful and not just a very lossy transmission (aka generator/pump running a motor). The original porsche had batteries. |
You should be doubting me, was off by an order of magnitude in the calculation! ;) I used 1300N instead of 13000N for the weight of a 3000lb car. It looks like it's about half the mileage increase on the city cycle with the other half coming from operating only at high load and engine stop/start.
The storing of energy allows more efficient (hybrid) energy management schemes, and not just losses from weird transmissions. |
I think the William Arnold & Sons 1897 car was the first. On the bottom of page 13 of this link it states...."William Arnold & Sons built Benz-like cars with their own 1.5 hp engines. One was fitted with the first electric self-start dynamotor, which also assisted the engine on hills."
Pioneer Vehicles for Car the Definitive Visual History of the Automobile The single cylinder motor was ONLY 1,190 cc and the car would run 16 mph |
