Wr250x
First post, glad to be here.
I have a Yamaha WR250X - factory pics here.2009 Yamaha WR250X Gallery It has a water cooled fuel injected 250cc engine. 6-speed manual transmission. It gets around 60 mpg stock. I would like it to get 100 mpg when cruising in 6th. It seems to me the main area to address is CdA. I was thinking of: - lowering it by reducing the suspension travel and ground clearance from 10" to 7" or so - putting on a fairing, something like the Can-Am 125cc fairing at LANDSPEED, LAND SPEED RACING, SALT RACER, BONNEVILLE, EL MIRAGE, FAIRING, SEAT, FENDER, SCTA, but with lights, and with mirrors behind the fairing - doing some fuel tuning with a Power Commander (although I doubt there is much to be gained) The exhaust has a catalytic convertor, but no lambda sensor. I'm not sure what changes are most effective on motorcycles. (I have been to Vetter's web site). Maybe: - Cover the rear (laced spoke) wheel with dish covers - Make sure there is no brake drag - Bearing grease and engine/transmission oil - how much difference can this make? - Gearing - it is easy to change the final drive ratio by changing sprockets. What would I shoot for? - What else? EDIT: What I would really like for the fairing is to make it out of a stretch fabric, like BMW did on one of their concept cars. |
if you use synthetic oil make sure that you use a wet clutch compatible engine oil or you will have to replace your entire clutch, amsoil makes a motorcycle oil that I use and like.
I haven't been able to find anything wrong with foam air filters, they are high flow, you can wash them and they catch more dirt they any other filter I've used. touring tires, they tend to be good wet/dry weather tires, they wear for a long time and if you can find some that are made out of silica rubber then they should be lower rolling resistance without sacrificing traction. An o-ring chain is going to last forever but it's also going to weigh the most, a good non o-ring chain with chain wax or bo-shield on it should last a number of years. as for a faring, the rear of you is the least aerodynamic part, so building up your seat behind you will help, wearing a small back pack, having a fearing that helps to keep the air flow attached behind your legs, removing the rear fender/license plate holder, dropping your handle bars a few inches so your whole body is dropped. |
First aero, then gearing (since you won't need the same power to cruise at speed).
Ryland's right: don't forget about the rear. I take it you've seen some of the other project bike threads here (like the electric aero Ninja 250 and the fairing/gearing project going on with the Suzuki Burgman). Welcome to EcoModder. |
When you start with aerodynamic mod's you will find out that at higher speeds more power is left to do acceleration. This means that you can use an higher gearing and lower the rev's and fuel consumption. A manual six gearbox is ideal for that. An other thing to address is the engine temperature. I have problems on my Suzuki Burgman to get the temperature in the cooling water after reducing the air resistance. I already reduced the air to the radiator with 50%.
I am very interested in your project. |
Do you mean your Burgman engine has trouble reaching (or staying in) normal operating temperature range? The WR250X cooling system has a thermostat, so flow through the radiator is (mostly) shut off if the engine is cool. Ryland: Synthetic: Yes, I plan to move to the Yamaha-approved synthetic. Foam air filter: check (stock is foam) Lower handlebars: Good idea. So far I have shortened them by 2" (from 30.5" to 28.5") to reduce frontal area a bit. I will have to see what it feels like with lower bars. |
[/QUOTE]Lower handlebars: Good idea. So far I have shortened them by 2" (from 30.5" to 28.5") to reduce frontal area a bit. I will have to see what it feels like with lower bars.[/QUOTE]
You may be able to use your stock bar for this. Remove everything, flip the bar end over end so that the rise now lowers the handgrip surface. Check for clearance to the tank at full lock steering. |
I flipped the bars to give it a try. It gave about a 6 inch drop from where they were. I might also try a set of straight bars. I can bend bars out of EMT for testing, that will be fun.
Hmmm, bars you could set high for slow speed riding and then swing to "dropped" position for highway riding would seem ideal. I already have 17" and 21" front laced wheels I can swap out, and 17" and 18" rear wheels. I can also have a 19" front made, if I like. The 21" front raises the front of the motorcycle by 2". I'm thinking that I want: - low rotating wheel mass for starts and stops (low rim, tire, and tube weight) - low rolling resistance - reduce frontal area (low chassis and narrow tires) - reduce drag of the front wheel somehow (partial "pizza pan"? wheel fairing/fender?). I guess the rear doesn't matter as much, but I don't know. It would point toward 17", or at most 19", front wheel. At the rear, it seems like 17" would be better, because the rider would sit a little lower. Does all this seem like the right direction? Does anybody know if radial tires on motorcycles tend to have lower rolling resistance than bias ply? I need some accurate way to measure fuel usage. Motorycles don't have OBD-II. Mine is fuel injected. Does the mpguino measure injector pulse width * pulses, and given injector data, display how much fuel is used? |
Boy I dunno about spending too much time on aerodynamic improvements for the WR. If you spend time and money fitting smaller wheels I think it will be unlikely to make a noticeable difference. Changing the bars is a good effort and with EMT you can custom make 'em to your liking, not some off the shelf bend. I really like the adjustable bar idea!!!
If you're really looking for outstanding aero, start with a 250cc cruiser like a Suzuki GZ250, or Honda Nighthawk 250. These are already really low, can be fitted with skinny tires and the gearing adjusted. Adapt/create a slippery fairing on these and it seems that 90+mpg should be reasonable. For the cool WR, play with gearing to complement your riding style. Go as tall as reasonable, downshifting for a sizeable hill on the freeway is no big deal. Maybe a small windshield to slip some air around your torso. The 100 mpg target is only really possible with good hypermiling technique or truly outstanding aerodynamics. Since the WR is set up for hooligan fun, not aero, just enhance it with minor mods and good riding technique. You'll be getting more smiles per gallon than anyone. |
you should be able to get clip on handle bar (crotch rocket style that clamp on the forks) they are lighter and lower then normal dirt bike handle bars.
If you cover the wheels I would just cover the rear as covering the front is going to make it handle like it has a sail on the front, a cross wind might get you killed, and as it is the spoked wheels are like egg beaters of course they are going to be better then wide flat blades hitting the air dead on. I assume it has alloy rims, if not look in to those, they are pricey. I changed my front sprocket on my Honda cb125 to a tooth larger and it made a world of difference and was around $15 and took minutes to change so if you can i would say order up a handful of sizes to try. narrower tires are going to be lighter but I tend to go with good tubes over thin tubes as you only have two tires. |
Yeah-I know I'm responding to 4 month old posts!
you need a smaller one at the rear . or bigger one in front |
Not my goal!
mine is a klr 250 1997 with 6 gear and when there is a hill at 100 kmh , i need to put it in 5th gear to keep my speed at 100 kmh these engine are perfect for city driving , mine is very pleasant to drive but it seem to rev too much high at 100 kmh ... at 90 kmh , my rpm is 6000 .... Pretty high so i think i will buy a drz 400 next summer . more tork , more hp , lower rpm and more fun! |
More efficiency for the WR250X
The X already has 17" wheels, so that's not going to be a great place for modification. I guess there are two ways to work on improving mileage, too. Highway mileage is interesting, but around town mileage would be really interesting for a bike like this. I just bought a used WR250X and it seems like the perfect urban commuter if mileage could be improved. For the last few years, I've commuted on a Kawasaki KL250 Super Sherpa, but that bike is all but worthless in the cold months because the carb just refuses to work in cold weather. The injection on the WR is the cure for cold weather starting.
:thumbup: Tuners seem to be clueless about improving efficiency performance. I also ride a 650 V-Strom and I've never found a tuner who knows where to begin in improving that bike's mileage. They have all sorts of ideas for getting more power, but mileage is completely beyond their scope. Tom |
There are some big tanks available for the WR, but better mileage would be ideal. I don't even close to have the inseam for the R model. Hell, I barely can get on the X. I use soft bags and a tailbag for luggage. I'm thinking about trying one of Acerbis' bolt on windshields for aero and wind/rain protection.
I live in Minnesota. I just got the bike last week, so I haven't had a chance to test my bike or my inseam, yet. It's about as tall, now, as my V-Strom, so I should be ok. I'll let you know if/when/how I'm wrong.
Direct from my 2008 - 2009 Yamaha service manual the seat height for the WR250X is 35.2" the WR250R is 36.6" you may want to look into the lowering link for the rear suspension just in case...
Been there, done that. I'm also installing the "step seat" for another inch. Dropped the stock shock setting to its lowest position and lowered the forks 13mm (max recommended is 18mm). Wish it would quit snowing so I could try it out.
Remember that your body is quite draggy - tight leathers will get you a bit of an improvement over floppy textiles.
Carefully remapping the FI system is nearly always good for a significant improvement. The aero stuff should help. Riding slow will help a lot:) Make sure the engine temp stays above 180 deg F. |
