should i raise the trunk lid, 'kamm the back, or both?
Here is a pic. The red diagonal line is 12 degrees, the yellow over rear wheel is current wheel skirt, Yellow at front is what i would like for airdam...any suggestions?, you can see for yourself the proposed kamm and raised trunk. which of the three positions should be used for the kamm? if this design can be improved or you have ideas please let me know.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
