WTB 14" ford contour alloy rims.
1 Attachment(s)
done a lot of digging but i found out theres a OE alloy rim thats 14" that fits the gen1 ford focus, that was sold on the ford contour and its merk twin...
the issue is the focus uses a odd ball 4X108 mm lug pattern. thats not very common in the usa, but for some reason the contour uses the same pattern.. im in zip 97048 not a grate photo, but this shows the rim. |
Dude, try this link. It will take you to the roadkill customs bolt pattern cross reference guide. It will cross reference your wheels to every car you could ever imagine. It will even give you the stud size and hub bore. The only thing that might be trouble is finding the right offset.
Wheel Bolt Pattern Cross Reference Database and Conversion Guide Or you could try this one which is a little more difficult to use. http://adaptitusa.com/referencebook.htm Now we just need one that lists the wheel weights and we're good. |
