Wtb:99-00 civic hx cvt harness
I have a project I would like to complete and I need this harness to get it done. If you guys find someone parting out a civic hx, has to be 99-00, please let me know. I really would like to follow through on my d15b 3 stage vtec.
Your doing a 3 stage with an auto?
I will but for now I will be running the the d16y5.
you can use a stock d16y8 engine harness. tie the vtec oil pressure switch into the 16v vtec wire and just run wires from the ecu to the 2nd vtec, egr valve, egr control solenoid and econo light. i have the ecu pin outs to do that if your interested!! let me know...
I have wiring diagram except for the econo light. Whats the pinout location for obd2b and how do I wire it? Does it output a negative or a positive signal from the ecu pin? |
- The green plug on the rear of the gauge cluster is for the cruise control. - The yellowish tan wire on the green plug is constant power.Wire it to the battery or tap it into a 12v source. - Then wire the red blue wire on the green plug to A30 on the ecu. This is the ecu triggered ground. |
Well that doesn't help me much, you did read that I needed the 99-00 engine harness right?
an old thread I know, but I figured I'd reply to clear up a few things. The 99-00 civic HX is the ONLY platform that used an OBD2a harness. So the obd2b ecu of any kind will not mate on to that car. A complete obd2b harness from an ex would be the closest match.
Thats's good to know. I'll have to remember that. Also interested in your quest for the 3-stage, so make sure you start a thread or link me to it if already done so.
Unfortunately........I got into a minor rear end accident. Because there is frame damage the insurance company might total it. The damages look like it might total more than the value of the civic.
Damn, sorry to hear that. Hopefully everyone is ok. I'd really like to see more positive posts on the 3-stage with people that actually do the research and put in the time to get it running right.
You should already know that all the info has been collected over at d-series.org. Come on man!!! We've been at it for so long. All of the wiring has been confirmed, Even have someone claim they were able to run a 5spd setup on the obd2a automatic ecu, just has revving issues but it still works.
