Go Back   EcoModder Forum > Classifieds > For Sale
Old 11-19-2009, 07:58 AM   #1 (permalink)
FS: Dual EFIE Box
I'm selling a used EFIE unit made for vehicles with dual bank O2 sensors. It also works with single O2 sensors, however if you have a V-6 or V-8 then you need this unit since there will be 2 O2 sensors off the engine. Works perfectly, and in perfect condition. Will sell for $40 or best offer, and I'll pay for shipping.
Thanks
JOE
Old 11-19-2009, 02:38 PM   #2 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
What does it do?
Old 11-19-2009, 10:21 PM   #3 (permalink)
The EFIE is used to intercept the oxygen sensor signal and then lets you adjust it before it reaches the computer. This allows you to manually force the engine to run leaner. Some people gain mpg using this, some use it to make full use of their HHO generator.
It gets wired into the oxygen sensor circuit and you set it up using a volt/ohm meter and a small flat screwdriver. Once it's set up you can then turn it on or off with a on/off switch that's built into it. I had mine mounted inside the glove box and could turn it on after I set cruise control and watch the mpg gauge slightly increase. Or you can just leave it on all the time.
Old 01-04-2010, 11:30 PM   #4 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
Wow, that is absolutely insane. As I was driving home from Denver I thought "Hey, someone should make a box that intercepts the signal from the O2 sensor and tweaks what the computer reads"
Small world sometime.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Zemco Compucruise 44 New In Box... clbolt For Sale 29 06-25-2013 06:18 PM
Pot Box Question ev59rag Fossil Fuel Free 3 07-14-2009 04:21 PM
My Eagle Research EFIE cfg83 EcoModding Central 17 01-05-2009 06:13 PM
FS: Puch Moped, 80-100mpg WI or MN Ryland For Sale 0 03-23-2008 01:09 PM
