Yeah we all know its a scam
Is there any good proof out there that HHO systems are big on hype and none on positive results?
Has any one out there been able to burry this dead horse once and for all? |
Nope. Usually gets sent to the Unicorn Corral for feeding and a brushing.
With diesel, it's already been proven that a mild propane or cng system gets the mileage way up. The MSD/Superchips electronic unit got an unladen Cummins Dodge to 44 mpg. During the Diesel Power Shootout, one guy got his Duramax to near ( or was it over ) 50 mpg with a homemade CNG system. The guy that won ( Dmitri Milliard ) pulsed his nitrous system to 36 mpg ( 1200hp twin turbo Dmax ). Go over to the Diesel Power site and do a search, it's in there. |
...you can do the same/similar "improvement" with 'shots' of NOX too, because all you're doing is introducing a different fuel into the combustion process, one that either "boosts" power (NOX) or economy (CNG, propane, etc.).
...however, the REAL effect is simply that you're adding more fuel, albeit a different fuel, into the engine. ...add both fuels together, and your net "gain" is seldom above zero. |
Bring this stuff up and battle axes and cattleprods pop out.:eek: Sauteed Unicorn over a bed of leafy greens and a horn garnish anyone?:D |
I did lots of reading on this. When running propane or CNG it seems like when you account for all the BTUs in the diesel and the BTUs per mile you get from the "gas" you get 3% to 5% more fuel economy that you cant account for. Since the diesel is a heat engine BTUs per mile seems to be the only natural way to measure effectiveness when you have more than one fuel induction system on any on road heat engine. |
It gives a reduction in (combined) CO2 output; emissions are lower because the diesel burns better with the gas; and a financial profit as either gas is less expensive here than diesel. |
can you provide supporting links pls?
New CNG tank setup in truck - Diesel Place : Chevrolet and GMC Diesel Truck Forums
http://www.mrsharkey.com/lpg.htm I thought every one that was a diesel modder knew of propane/natural gas fumigation. |
Of course we know about the "drugs"!:p
mmmm horse tacos :thumbup:
...when ALL the energy contents per volume are accounted for (assuming constant volume, of course) it comes down to effective proportions of BTU content of all the fuels. Look up Gasoline Gallon Equivalent on GOOGLE.
...I've always associated ether with "starter fluid" for cold diesel earthmoving equipment, but, yeah, it'll "burn" too. ...NOX supplies additional oxygen, which helps combustion and HP output, but not MPG! |
It's this sort of benefits the HHO-crowd is screaming about, but can't realize as they have to produce their own H2. Of course, going CNG all the way is better than diesel, but adding it to diesel is apparently more easily accepted in the transport world. The bi-fuel trucks will still run on diesel alone. |
OOPS, shoot, that's why we don't have straight CNG trucks now. |
...maybe the French should come up with a "Champagne" fuel, ie: "Bubbly-Gasohol" that has CNG 'bubbles' pumped into it?
...it could be labelled Super-Magnum (93), Magnum (91), Bubbly (89), and Spritz (87). |
We have so much natural gas it's ridiculous.
No, we don't. What's usable and what isn't are in contention, and subject to misinterpretation. There's NG that we'll not ever be able to afford as the EROI is so out of whack with reality. Propane is the better addition to a diesel for several reasons (with the way things are). One, it can be found all over the US. Second, it's a cheaper conversion. Third, it can be used for quite a few appliances for heating and cooking that a truck provides a portable fuel source for (and NG is not easily usable in the same way). Propane -- again, in a truck -- may provide some additional range for the more valuable store of diesel, and, IMO, it's more important to think of the work value of goods transportation for ones family. A margin enhancer. |
CNG is cheaper to use but the start up cost is high and its difficult to store a lot of CNG on a car or truck.
I wouldn't mind running propane again but I think my compression ratio with turbo is too high, if I did use propane I would only be able to use it in say the 2-6 psi of boost range. I have considered running water methanol at lower boost. I think I would be better off running water methanol since it would enhance the temperature differential between both the hot and cold reservoirs. The evaporation of the water methanol makes part of the cold reservoir cooler, then when the diesel is injected and lights off the methanol, both burn off and help make the hot side hotter. |
The race truck gets 30 mpg on the highway. Does over 160 mph. Stock cam, heads, intake manifold, etc. Good stuff. |
I just buy products from heath, never read his stuff.
Looks like I am about to start. I have herd heath likes to fill there high power blocks with block filler up to the bottom of the water pump inlet holes. I thought about adding some block filler (since I did build the engine up from a bare block in my living room) but didn't want to add another 30-50lb of weight to the engine. I would rather have 30-50lb more load capacity or get up a mountian that much sooner. I have herd the 6.5T doesn't do well on water methanol. Only thing I can think of is there timing could be too far advanced on a stock engine. Heaths 2bar blown diesel could be running less timing than a normal engine. |
True on the block fill, and the engines don't run hot at all. The pump that he uses is an off the shelf Stanadyne DS4, and they use their software upgrade with a higher rpm limit, nothing that a customer can't purchase themselves.
The engine can handle water/meth just fine. There's an article in Diesel Power about the LSR truck that Heath built. Like I said, good stuff.:thumbup: |
I looked up the diesel power article on heath, they said he was running pure water, to the tune of 1 gallon of water for every half gallon of fuel burned.
I will be using the 6.5 turbo block with 6.2L heads and fuel system. I wont have any of that PMD nonsence. Also I have no problem sticking well below the 4,400rpm limit mechanicly built into my DB2 injector pump. |
-soD |
An adsorbed tank would eliminate the need for a $3k pump every year and eliminate the high cost of NG cars. |
Absorbed gas? like the way you dissolve Acetylene into acetone for storage and transport?
Adsorbed Natural Gas Technology G-TEC Adsorbed Natural Gas Cylinders |
Sounds simple enough, gas cylinder + active charchol + mild compressor.
Any idea what the start up on this is? With the "american way" its $100s of dollars for the tanks and the high pressure boost compressors run about $3,600 (last time I looked). |
I tested HHO generator with my diesel.
Even when I add more fuel to the engine (the HHO), as my engine is not electronicaly controled, when I switched ON the HHO generator the engine diminishes rpm in the same way as with Air Conditioner. The HHO generator was my second versión build, improved, with 11 cells, very efficient, but even though, for me it was clear that the generator was sucking more energy from the engine than the energy it was providing burning the HOH gas. If the gas had been giving additional energy, the engine would have increased its rpm, as if I was accelerating a Little more, i.e. injecting more fuel. Besides, the HHO generator had to be fed with wáter. I worked a lot in the system, but reality showed me it was a fiasco. Not any theoretical consideration or prejudice. Just doing. Oldbeaver Note: What if we had to generate our gasoline or diesel onboard? My impression is it probably would had a negative energy balance too. |
Can you give us a few more details?
Your test procedure would also be helpful. |
Diesel engine tested with an HHO generator
2 Attachment(s)
Ok, here are some more details:
1) The engine tested was a Nissan RD28, 3000cc, 6 cil in line, naturally aspirated, 18 valves. Made in Japan in 1996. This was about 6 years ago. The engine is still working in very good condition, was perfect then. You can see it here: https://sites.google.com/site/rd28engineswap/ 2) From what I recall, the current draw from the car was about 20 A, but variated up as the wáter warmed up, reaching 25 A aproximately. 3) Gas production was so high that pushed wáter down, diminishing the production surface covered with wáter. To solve this and use all surface in production, I added a small 12V electric pump which blew the gas to the bubler. This solved the problem. I am attaching a couple of pictures of my HHO generator. It is made of very heavy and non corrosive Steel, which is very hard to make holes on it. I broke many perforing elements to make the holes. I couldn't cut Steel, so make them cut it with special machinery. Even so, as I said in previous email, car didn´t benefit from the gas, which I injected at the air income of the engine, after the air filter. Oldbeaver |
If you can build that HHO generator then you should really try building something proven to work like an air dam or any one of the other 70 or so things proven to work.
For some reason people tend to gravitate toward mods that don't work like gas tank pills, hho or some over elaborate combustion process modification that is so complicated no one can explain how it works. |
Uh, there's a BIG difference between an "...exercise in frugality..." and an "...exercise in futility...". And, the wise observer easily discerns their difference for themselves.
Air Dam and proven mods instead of HHO
Yeah, sure. I like to experiment. I also built an air front cover, but for my Skoda Octavia. Performance improve difficult to measure, anyway. Is that what you mean as "Air Dam"? What are your favorites among the 70 that do work? I like the ones that don´t change the original look, and produce the most bang for the buck. Do you mean the 70 mods listed in this site? Oldbeaver |
A front air cover sound like a grill block.
The air dam keeps air from getting hung up on the under side of the vehicle. An air dam and grill blocks can change the vehicle appearance as much or as little as you want, only thing that limits the visual impact are your imagination, time and budget. See this: Car MPG Efficiency Modifications Main - EcoModder Some mods are vehicle profile specific so they only apply to pickup, car or SUV bodies. Others are engine specific there are big differences between how the same mod can effect diesel versus gas engines. |
Just because . . .
But, the science for HHO is there, though not in the simpleton assessments of the typical internet discussion. And the gains to the average person are not in line with the costs involved. It's probably better to zip tie pie tins on your wheels. |
The application of HHO is far more complex than most realize.
Without a feedback loop and variable gas output from your generator, the application becomes largely hit and miss. |
I am fairly certain no one has gotten it to work.
Why would I waste time building an HHO machine, that is only proven to deliver no results and inconsistent and inconclusive results at best, then always have to tinker with it, adding water or doing what ever you do to make them go. Then if you do get it to work the oil company has you killed. Why would I bother with all of that mess when I can build an air dam once, in a day, for about $20, using low value scraps for most of it, never have to mess with it unless the lawn edging gets torn off and gain almost a full MPG? Last week I was in Maine, the high temperature most days was well below freezing. In that situation the air dam is not effected. How does the water filled HHO machine do? |
