EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   You should lower your car (https://ecomodder.com/forum/showthread.php/you-should-lower-your-car-41108.html)
jimchitas 09-24-2023 03:54 AM
I looked at the most ecomods here and i notice "nobody" mention this mod first of all, in the tuning scene and Motorsport scene we have seen the 80% percent of modified cars using coilovers to lower the car to look better and handling but can we use it for a more aerodynamic car we certainly can if its done properly.
Firstly lowering the car decreases frontal area! So lowering the drag force's
But also you have less air underneath the car will reduce the drag coefficient
Lastly you are going to have better handling so its really the cheapest mod out there but a good one
oil pan 4 09-24-2023 09:32 AM
I can't lower vehicles. The roads where I am are junk and every time it rains the roads flood. I see lowered cars all the time with ripped off bumpers, damaged bumpers from hitting the road where it dips, catching a curb or parking space block.
Plus lowered vehicles ride like forklifts.
Phase 09-24-2023 12:05 PM
When I get the new Prius, I’m going to get an adjustable air suspsneison so I can lower and raise it whenever I want. Permanent lowering just doesn’t work for my ski resort and dirt road driving
freebeard 09-24-2023 12:56 PM
Once aerohead got out of my Superbeetle at the Salt Flats, and was surprised that the ground was so close. :thumbup" My limit is 3.5 inches, for the three bump strips to get from Main Street to my place. The tow hook scrapes as it is if you don't cross at an angle.
Get a Type III, the torsion bars are adjustable without affecting the ride.
The panel van could ride right over the 6" concrete stop blocks in big parking lots. The Metro isn't getting lowered, but might get four front/rear wheel spats.
aerohead 09-25-2023 10:49 AM
fly in the ointment
In a past thread here, years ago we discussed the Audi A2, which was aero-modded by Chalmers University at MIRA in 2012.
One of the tricks they tried in the wind tunnel was was 'lowering.'
The A2 did not demonstrate any drag reduction.
And I don't know of any economical way that a member or guest could 'simulate' lowering their car, just to 'see' if testing produced a significant enough benefit to justify the expense to provide 'active' suspension.
Just dropping a car, as others have already mentioned, is a recipe for ground strikes, and 'missing', or damaged components.
I have a collection of underbody aerodynamic bits from Corvettes, Firebirds, and some kind of Audis knocked off at a nasty intersection, and Kroger Supermarket driveway ramp in Denton, Texas.:o
freebeard 09-25-2023 12:00 PM
VW Type III front torsion bars are adjustable.
When I was in high school we took a classmate's father's red Valiant station wagon into Salem to drag the gut. We'd drive to the end of their dirt driverway, jack the car up and crank the torsion bars down and head for town. Coming back, we'd jack it up and raise it again. Took a few minutes with many hands.
67-ls1 09-25-2023 10:59 PM
I’m not convinced that lowering a car automatically reduces resistance. Especially on newer cars that have pretty aero undercarriages.
And adding coil overs to lower a car is FAR from an inexpensive mod.
Piotrsko 09-26-2023 10:53 AM
It's just super bugs that aren't equipped with torsion bars in the front and maybe bussies. Everything else aircooled is, more or less, but sometimes not as easy as twisting the ends. There's a wierd process for doing an exact amount in the rear because the splines are odd counts.
j-c-c 09-26-2023 10:29 PM
A few counterpoints, explain how lowering a car reduces frontal area.
I will concede it should lower drag as most car bottoms are very draggy.
Lowering a car mainly lowers COG, that does not automatically across the board improve a car's handling as there are many other factors at play and it actually may worsen handling.
Additionally, when one does have ride height adjustability, it should be mentioned "rake" is another consideration in reducing drag
Phase 09-26-2023 11:10 PM
Tire frontal area is reduced. So lowering an inch reduces frontal area by about a square foot give or take.
freebeard 09-26-2023 11:19 PM
Chopped, sectioned, channeled and dropped. :thumbup:
https://i.imgur.com/3Xq3V4E.jpeg
https://imgur.com/3Xq3V4E
cRiPpLe_rOoStEr 09-26-2023 11:51 PM
I remember seeing some slumdogs claiming their lowered cars accelerated faster and could consume less gasoline on highway, but they were a PITA to drive in town. My only experiences with lowered cars were also not any good.
freebeard 09-27-2023 12:49 AM
Look for the video of the guy getting into the Woodruff Special. He starts out on his hands and knees, crawls in and rolls over, then swings his legs in.
I literally could not do that myself.
j-c-c 09-27-2023 07:29 AM
If rear tires are 100% included in frontal area calculations and one lowers the car 1", to reduce area by one square foot, each tire must be equally 36" wide.
Want to try again?
j-c-c 09-27-2023 07:31 AM
I guess those frontal protrusions pictured are of little concern in the drag coefficient vs frontal area battle?
freebeard 09-27-2023 12:23 PM
It's all in what aerohead would call a favorable presure gradient. It would be worse if the shock absorbers were stiill present.
j-c-c 09-27-2023 04:09 PM
Or maybe a Gurney Bump even.:rolleyes:
cRiPpLe_rOoStEr 09-28-2023 12:14 AM
There might be some easier way :D
https://c8.alamy.com/comp/BE6F6G/mr-...oof-BE6F6G.jpg
j-c-c 09-28-2023 09:54 AM
You mean not being lower?:D
aerohead 09-28-2023 10:35 AM
'protrusions'
With the front and rear mutilations, along with the exposed wheels, it wouldn't matter much if the body was there or not.
You'd be competing with an Arial Atom, at Cd 0.65.
Beautifully executed though!
cRiPpLe_rOoStEr 09-29-2023 12:57 AM
That would be quite obvious :D
But anyway, maybe it wouldn't be too hard to do that Mr. Bean armchair trick with that chopped Beetle...
