Your Record tank for 9th gen Accord (non Hybrid FTW)
2013 - 2.4L-EX-CVT-NON Hybrid-sedan w/deck lid spoiler
*Only Shell gas *MobilOne 0w20 Adavnced Fuel Eco Full Syn *51 PSI all around *Bone Stock New to this site & am dying to know if someone's done 1,000 mile tank on a 9th gen NON Hyrbid 2.4L Accord! I know it's possible! My personal bests to date (not necessarily the same tank): 964.6 miles (47.5 tank avg) 47.5 mpg tank avg (above tank) 20.611 gallons pumped (different tank) 57.5 miles run past 0 range (one stop and start past 0 range) All the #'s are based on 75/25 highway/city and are with either vent or no vent (no AC or fan). |
From what I found in the Garage, there is no one else close to you except for a hybrid. Congrats, you are in a league of your own! You don't have much work to do before reaching the 1000 mile mark :)
Also, welcome to Ecomodder! You should create a Garage entry for your ride. You are doing very well :thumbup: |
Honda lists the fuel tank capacity of a 2013 Accord at 17.2 gallons. How are you getting more than 20 in? Is there that much unused capacity in the tank and filler neck?
Welcome aboard! |
The numbers are based on tip topping it off, as in, the car won't take any more gas topping it off. It's also based on running it past 0 on range. It's safe to assume that there is more than one usable gallon of gas left after hitting 0 in the 9th gen Accords, probably more like 1.5gallons. |
