Zivan NG3 Charger - 115VAC input, 144VDC output - $630
$630
Zivan High Frequency Battery Charger NG3 Item is used and in very good condition, perfectly functioning. Label states output of 144VDC at 11 amps, although factory sticker on side indicates charging of various types of flooded lead acid batteries up to 172 volts (see picture). Charger can be shipped to Zivan USA to be factory set to custom voltages and tailored to your particular battery chemistry - AGM, Gel, Flooded SLA, Ni-Cad, NiMH, Lithium or any other rechargeable battery that may come on to the market in the future. I have not verified, but have been told this can be done by Zivan for less than $100. eBay *******s won't let me insert a link here, but you can check out www-DOT-zivanusa-DOT-com. This unit will not accept 220VAC input, but can be used with public charging stations that provide 110VAC to the car, and also charged from a normal 110VAC outlet at your home or at your workplace. I accidentally bought this used charger thinking it would work with my 220 volt charging station, and I am selling it to buy one that does. Here is a link showing the selling price of a new Zivan NG3: www-DOT-electricmotorsport-DOT-com/store/ems_ev_parts_chargers_zivan_ng-3-DOT-php User manual download is here: www-DOT-zivanusa-DOT-com/pdf/NG3-DOT-pdf Dimensions: 16.92" L x 8.66" W x 3.54" H Weight: 5.5 kg = 12.2 lbs Thanks for looking. |
I still have the charger. I will give you a better price than stated above. Let me know.
My email is mcbrems_AT_gmail.com. Thanks, MB |
