Old 06-16-2009, 01:43 PM   #11 (permalink)
beatr911
B2300 - '96 B2300 SE
Big Red - '88 Concours ZG1000
90 day: 54.41 mpg (US)
Zongshen Sierra 200 - '06 Sierra 200 Supermoto
90 day: 82.11 mpg (US)
OOPS! Should've read the original post. Guess you did the gearing.
Well I still think you can reach 100 mpg. I picked up 5+ mpg on my Connie by lowering the fuel level in the float bowls about 10mm, effectively leaning all circuits. This may have other adverse affects on the main, but I almost never dip into the main circuits.
To do it better weld in a bung on the exhaust and install a cheap O2 sensor and monitor the voltage with an AFR gauge or a voltmeter. Adjust jetting, air orifices and mixture screws accordingly after doing good research on how your carbies work. This will get you pretty darn close and you won't spend $400 on a wide band set up.
Additionally, I'm considering using intake air heat to seasonally fine tune the carbs though I don't know how effective it will be with the CV carbs we have.
