Old 04-16-2008, 09:13 PM   #6 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by Volones View Post
That's exactly what I was hoping.
I do have a distributor, so if it's getting a signal from a low power source, I should have no trouble splicing the shift knob wiring right into that.
Thanks so much MetroMPG!!!
Bear with my noob-ness on understanding vehicle electronics
My distributor has 3 low-voltage wires:
  1. Tach output
  2. Feedback to the ECU, and a
  3. 12V wire between the Coil and Ignition Control Module
I assume that opening the circuit to the last wire (between the coil and ICM) would do the trick (or would any disruption likely confuse the ECU?)
I don't EOC all that often, but when I do, a kill button would be great -- especially to keep the gauges, signals, and ABS active.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
