Old 05-05-2008, 01:43 PM   #6 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Originally Posted by larrydag View Post
When I get free time I'll give it a go. One thing I will need help with is the VSS and Injector interface hookup with the car. I've never done anything like that before. I understand we are getting most of the pulses from the ECU. If anyone has a good howto on that setup would be great.
Normally the injectors will all have a red wire, this is not the wire you want, it is 12v power. You want the other wire going to an injector, the one that is grounded by the ECU to turn on the injector.
Does this help, should I take some pics. Also detailed text attached.
