Old 05-05-2008, 05:46 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
(edit, despite the below, I'm going to tap the injector lead directly)
I'm planning on starting at the ECU, but it requires knowing what is where on a particular ECU, which may require some decent documentation or some probing around with a multi meter. Here is a late 90s saturn s-series, with 4 hookup points (vss, injector 1, battery, ground) for example:
