Old 10-03-2011, 04:46 PM   #1 (permalink)
MetroMPG
90 day: 50.45 mpg (US)
Winter beater Metro - '00 Chevrolet Metro
90 day: 64.43 mpg (US)
When is "old gas" too old to use?
An article on Autospeed got me wondering about this.
I was surprised to read the experts giving answers that were much shorter than I would have expected.
Depending on whom you ask, gasoline is good for ...
  • 6 months - in a sealed container, after which it starts to degrade
  • up to 12 months in a sealed container
  • "several months" old fuel in your tank risks fuel system problems
  • "several weeks" is enough to detect octane degradation, based on dyno testing
Read more from: The Life of Fuel - How long does fuel last in your car's tank?
When I got the Firefly, it had been sitting, the tank nearly full, for seven years. The engine started normally on the old gasoline, and it ran apparently fine when I test-drove it around the block.
7 year old gas
7 years seemed pretty extreme, though, and I was warned that old gas could gum up the intake valves and make them stick. So I drained the fuel tank to nearly empty, drove straight to a gas station and filled up with fresh gas before driving it home.
OK, so if 7 years is too much, how about four years? That's how old the gas is in this 1990 Swift GTi:
4 year old gas
... and with a boost, it started right up after sitting in a field for that long.
On the other hand, I have had trouble running a 2-stroke boat motor with fuel that was 2 years old. Maybe it depends on the engine, or the oil mix causes things to go wonky sooner.
Autospeed: The Life of Fuel - How long does fuel last in your car's tank?
Latest mods test: 15 mods = 15% MPG improvement: A-B test, 2007 Honda Civic 1.8L, 5-speed
Ecodriving test:
Manual vs. automatic transmission MPG showdown: Nissan Micra 1.6L
