Old 12-25-2012, 12:44 AM   #89 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
The open pcv valve is meant to pull direct vacuum on the crankcase. Which in turn assists in pulling the pistons down= more power/ better efficiency. It shouldnt cause a stumbling. If the ngk tune up doesn't fixit you might want to start looking toward the 02 sensor
