Old 11-21-2013, 03:49 AM   #2 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.3 mpg (US)
I drive with my mechanic every so often and on one occasion when I showed him how long it takes to start the truck, he said the ball valve in the fuel pump (or regulator, I forgot which one he said) is getting stuck and by holding the key for longer it builds enough fuel pressure to overcome the ball's 'stickiness'.
Maybe it's something similar? Have you tried running a fuel system cleaner?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
