Old 01-19-2015, 08:36 PM   #224 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Update: wheel skirts, WAI, and console
WHEEL SKIRTS: I got enough done to be able to mount one of the two wheel skirts I started months ago. This is also some smooth, thin, strong, and shinny black industrial type plastic (comes in a roll).
WAI UPGRADE: I used this info from "some other dave" as guide to update my WAI. The previous one was 3" left-over dryer hose. According to some_other_dave that would make the air slow and rough, not good for WAI. Also the hose retained no heat. This ABS plastic tubing is deliberately smaller than 98 DX spec air tube. Faster air, smoother flow, and ABS plastic gathers and retains engine heat The tube is more than 2' long overall.
If you look closely, you can see "ecomodder.com" under a layer of black paint on the WAI tube.
CONSOLE IMPROVEMENT: it's minor and does nothing for FE, obviously, but I painted the borders around the inject kill switch and the USB port the same deep forest green I have been using on various details on the car. Extending a green "theme" that has gradually developed.
ID:	16797   Click image for larger version
ID:	16798   Click image for larger version
ID:	16799   Click image for larger version
ID:	16800   Click image for larger version
The Following 3 Users Say Thank You to California98Civic For This Useful Post:
DukeEcoNukem (06-08-2016), j12piprius (01-21-2015), pletby (01-20-2015)
