Old 09-01-2015, 04:26 PM   #5 (permalink)
aerohead
geodesic
This is a great idea. My request is that you consider a geodesic construction. It can be laid out as a flat pattern with darts and cut from a single sheet. That will self-assembly into an accurate surface. Much less work.
http://starship-enterprises.net/files/3f%20icosa%20Peel%20Pattern.jpg
I can provide all the relevant edge lengths for a prolated ellipsoid.
'What do you think, sirs?'
It would be fun to see the geodesic structure under smoke,'n also get some numbers,but if I'm gonna make my target I better stick with what I know.
The model has got to be as close a representation of the drawings as I can do,so as not to introduce any unknowns.
The velocity and pressure profiles of a streamline half-body are dependent upon the compound curvature.
Windshield wipers and roll-down windows would need more 'conventional' surroundings.
IF a geodesic 1/3rd model were to appear in Ogden,Utah,September,2016,we'd be impelled to get it into the tunnel,and I'd sure help underwrite the cost.(hint-hint,wink-wink!) Plus,there's some pretty good Mexican food nearby.
BamZipPow (09-03-2015)
