08-31-2015, 06:20 PM
Baby template car for DARKO 2016
I've set my mind to a return trip to DARKO Technologies wind tunnel in 2016.
I've thought of at least 16 additional mods for the T-100 to test.
Since I'm going,it would be efficient to have at least 1-additional vehicle to test while I'm there (like we did with Gary's Prius).
I figured out that a 1/3rd-scale 'Template'-mobile will fit in the back of the T-100.
She'd be 21" high,42" wide,and just shy of 8' in length.Built up from plywood,foam,and fiberglass,she wouldn't weigh much.I've already located some 'scale' wheels at Harbor Freight Tools.
The 76-mph airspeed at DARKO is plenty enough to achieve critical Reynolds number and accurate Cd.
The model would be a way to verify the 'Templates' actual aero characteristics.
Also,if there's a member in the Salt Lake City area with a bone stock, 1st-gen Honda Insight,it would be great to do a meetup at the tunnel and throw your car onto the load cells and see how it's Cd compares to the A2 value from North Carolina.I'd cover the cost.
It allows one year for fabrication and even at my glacial pace,I think I can get it all ready by then.
The Following 7 Users Say Thank You to aerohead For This Useful Post:
08-31-2015, 09:50 PM
Spaced out...
Can't wait for the results!
Care to elaborate on the 16 mods you want to do to the 'yota?
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
09-01-2015, 08:03 AM
That sounds great. I would also like to know the 16 mods you are planning for the T-100.
09-01-2015, 02:57 PM
This is a great idea. My request is that you consider a geodesic construction. It can be laid out as a flat pattern with darts and cut from a single sheet. That will self-assembly into an accurate surface. Much less work.
http://starship-enterprises.net/files/3f%20icosa%20Peel%20Pattern.jpg
I can provide all the relevant edge lengths for a prolated ellipsoid.
'What do you think, sirs?'
Reason: swapped out example for smaller size
09-01-2015, 04:26 PM
geodesic
It would be fun to see the geodesic structure under smoke,'n also get some numbers,but if I'm gonna make my target I better stick with what I know.
The model has got to be as close a representation of the drawings as I can do,so as not to introduce any unknowns.
The velocity and pressure profiles of a streamline half-body are dependent upon the compound curvature.
Windshield wipers and roll-down windows would need more 'conventional' surroundings.
IF a geodesic 1/3rd model were to appear in Ogden,Utah,September,2016,we'd be impelled to get it into the tunnel,and I'd sure help underwrite the cost.(hint-hint,wink-wink!) Plus,there's some pretty good Mexican food nearby.
09-01-2015, 04:43 PM
16-mods
The list is at home but here goes:
*reworked airdam with belly and edge radius
*grille plug
*improved cooling ductwork
*reconfigured hood blister,widened out to edge of A-pillars,with NACA submerged-inlet /ventilation duct-to cowl inlet
*faux GTP full-compound,triple-curvature windscreen
*faux 'active' windshield wiper cowl area fairing
*new mini-mirrors
*mirror delete
*faux flush glass
*tape all seam and cut lines
*full gap closure between cab and bed
*restore missing belly pan section
*add belly pans to lower A-arms
*add urethane pan sections around rear axle gaps
*faux 'active' wheel fairings(before and after front wheels)
*ditto rear wheels
*lowered diffuser addition to boat tail (2.8-degree)
*add blended flow fence into lower perimeter to close in Coke-bottling
*lower rear skirts to former full depth and add integrated flow fence
*reconfigured aeroshell
*reconfigured boat tail
*reconfigured boat tail stinger (full-length)
*simulated suspension drop (deflate the tires)
Looks like I'm at 23 things to test,plus the model.
Reason: add data
09-01-2015, 05:52 PM
I assume the "faux" components would essentially be non-functional and used for the wind tunnel test, but the other components would be functional for use when driving the truck?
09-01-2015, 06:07 PM
faux
Yes,some of the things I want to test would never survive on the road unless they were active,to accommodate weather, road clearance,or DOT regulations.
The windshield would have to be 'real.'
I can't lower the truck so I'll just let the air out of the tires 'n see if it shows on the computer screen.
Flush glass isn't going to happen.Nor a pliable cab/ bed gap-filler,or unit construction.
Lots of Gorrilla tape and aluminum sheet,Formular,etc.,composite mockups.
I will be able to simulate a 'future' in which these things were part of a production vehicle.
09-01-2015, 09:27 PM
#9 (permalink)
Coincidentally, about the size of a single wheel trailer for a VW Beetle. Wink, wink; indeed.
Edit: Could I make a rear-steer reverse tricycle and put a ball hitch on a nose probe and have it track successfully, a least going forward?
Wait a minute—42"x3 is 10' 6" wide.
What size are your candidate wheels?
09-02-2015, 04:38 PM
#10 (permalink)
tracking/wheels
I think that for towing,the front wheels would have to be free to turn and rear wheel fixed,as when pulling with a towbar,or with fixed front wheels,allowing the rear to turn as on Bam's 1-wheeler.
The wheels are about 8.5" X 2.5".
