Old 11-09-2016, 11:09 AM   #9 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Yes!
However...
The unfortunate problem is that shaft / pulley defect also affects the camshafts via the timing belt, which is not visible in the video. The crank timing gear is hidden behind the larger pulley, but it's driven by the same key/keyway connection.
When the crankshaft keyway starts to fail, the camshaft timing goes off.
