11-25-2016, 02:07 PM
I had been following this story a little bit.
They also made a tidal-fed basin in the bay which captures water at flood tide, then closes the opening at slack water. Then they feed the flow back through a conventional hydroelectric turbine set-up.
Apparently they capture the occasional whale in the basin too.
(After which point there is a big sale on sushimi at the local grocery store?)
