Old 12-23-2016, 10:44 PM   #3 (permalink)
benfroggg
I was thinking a fan in the floor pulling air from under the camper into the camper with a closeable vent for cooling. Probably locate it under one of the seats with a shroud in front of it.
I just found another window I had laying around that opens. I might put it in the rear since its also less likely for someone to break in through due to it's size. That should help with ventilation as well.
As to the electric fan conversion... I should have added that I plan to install a real temperature gauge with it. Worst case scenario turn the heat on if the gauge goes up beyond normal operating temp and pull over for a while.
I do like the bright bars (we use a version of those for stage lights) but I'm pretty sure even on high beams those aren't legal here in Maine for road use.
The existing headlights suck! The LED replacements should be notably better than stock. Maybe some LED fog lights are in my future.
