Old 11-26-2007, 11:23 AM   #193 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
12-11-2006, 05:34 Pm
The EV list folks seem to be leaning towards it being a brush timing issue, but the expert requested another specific motor pic, and I'll wait to do anything until I hear from him.
If you want to see pics of the motor & its guts:
http://metrompg.com/offsite/baker-pu...or-detail.html
What I have learned:
You can eyeball whether a series motor is using advanced brush timing by comparing where the brushes contact the commutator relative to the bolts that hold the field coil shoes in place. If it all lines up (brushes inline with the field bolts, it's neutral timing.
A quick look at our motor shows that its timing is in fact advanced for stock rotation (the field pole shoe bolt heads are the painted ones on the casing with the hex heads - the black marker lines line up with the brushes when the end cap is in place):
We'd have to move the brushes the equivalent distance to the other side of the shoe bolts to have the same timing for the direction we want to use the motor.
Also learned: for "street" EV use, 10 degree advance is good. 13 degrees for racing.
Haven't tried it yet. Will wait to hear from Mr. Husted.
