Old 04-21-2017, 03:34 PM   #14 (permalink)
alexander.foti
Originally Posted by Piwoslaw View Post
Alex, I also have a commonrail turbodiesel in my Peugeot 307, and I cut not the cam, but the crankshaft sensor. I seem to remember that cutting the signal from the cam sensor would not kill the engine, or would add some other unneeded complications, and that is why I had to try my luck with the crankshaft sensor.
In the case of my HDi, cutting the crankshaft position sensor kills the engine without reseting the ECU, but I do get a message about oil pressure being too low.
It logs an error code, but the engine can still be bump- or key-started. The error code can later be deleted with an OBD tool.
Sorry, I wasn't clear on the first post, I did the crank position sensor too. You are right, on mine the car would still run with the CPS disconnected.
I get no warnings, but Mercedes are odd in that they don't have low oil pressure lights or sensors for that matter.
Like yours I can bumpstart or restart with the newly installed starter button. Seems like a good solution.
