Old 07-14-2017, 09:37 PM   #13 (permalink)
EcoCivic
It's easy to figure out how much power you need. Just use an amp meter and turn stuff on.
If you drive less than 30 miles a day a roof covered with solar and a real MPPT type charge controller would be more than enough.
Keep the alternative unbelted and powered down, most of the time, then put the belt back on for long trips.
Would it not hurt aerodynamics significantly and add weight to put solar panels on the roof? How many watts of power could I get out of a roof covered with solar panels on a bright, sunny day? What about putting a solar panel above the back seat so it gets light through the back window?
