Old 10-07-2017, 09:48 PM   #662 (permalink)
changzuki
Changfa diesel + Suzuki
changzuki's Avatar
Centurion - '74 FIAT X1/9 Centurion Full Race DNA
Last 3: 143.5 mpg (US)
Replacing the Original Centurion's water pump.
The original water pump is externally mounted on this Kubota D750.
A Quick Recap:
This particular early Kubota D750 was thermosiphon cooling which would not have been adequate for this application. So, to address this, R.Q. Riley added a water pump and thermostat.
The water pump itself is still relatively cheap if purchased brand new (under $25 USD). And the thermostat is about another $7.
In the last photo you can also see a new oil filter (it's red). While the water pump was off, I replaced the original Kubota oil filter.
Another project done.
~CrazyJerry~
