Old 10-11-2017, 11:17 AM   #16 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
JCP,
You can engine-off coast your Honda if you think it will be worth the risk, bearing in mind that if you turn the key a notch too far, you lock the steering. One click, not two.
Don't try to engine-off coast your Echo. Automatics need to be kept turning by the engine to maintain lubrication.
Aero improvements make P&G work even more, because you get to retain more of the velocity over a longer glide than before, and you need less input energy to overcome aero drag to get back up to gliding speed.
