Old 12-06-2017, 06:37 PM   #668 (permalink)
changzuki
Changfa diesel + Suzuki
changzuki's Avatar
Centurion - '74 FIAT X1/9 Centurion Full Race DNA
Last 3: 143.5 mpg (US)
-Centurion's oil filter-
In the previous posts, the external water pump (and hardware) was removed for replacement. During this time it was discovered the original oil filter was still intact. With this easy access replacement of the original Kubota oil filter was next on the list but it was not without it's own little challenge!
The auto parts store had a valid part number for a Fram oil filter replacement. Next to the original Kubota filter there is a small height difference - but it's enough to cause a problem - once installed, the filter contacts the shock tower.
Back to the auto parts and this time I brought the original filter and spent some time comparing it to the ones on the shelf.
Luckily a cheap Purolator was stocked and fit perfectly!
New oil and filter... onward ho!
~CrazyJerry~
The Following 3 Users Say Thank You to changzuki For This Useful Post:
COcyclist (12-07-2017), nemo (12-06-2017), Xist (12-06-2017)
