Old 12-12-2017, 10:58 AM   #10 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
A hotter thermostat seems to have helped on my diesel Golf. I had struggled to consistently get 55mph on the highway and now I regularly see 60 mpg average at 60 mph. The Stant Superstat keeps 207 F when the stock thermostat held 195 F. You don't have to worry about preignition in a diesel. Ignition timing is controlled at the injectors.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
