Old 02-12-2018, 12:05 AM   #102 (permalink)
niky
Fantastic job, Daox! Now I want to try that myself! Think it'd work if the bar mounting plate was mounted inside the hollow of the beam? I can see making the plate flat, and then welding a flange to fit into the beam area.
Niky... have you had the chance to try a 1.0 L Mirage?
Sadly, they have none here. I expect it could be pretty economical, as the 1.2 already hangs with the local 1.0 crowd very well. Only Suzuki makes a 1.0 that's even just a tiny bit better than the Mirage 1.2.
