Thread: new ebike build
Old 04-29-2018, 10:26 PM   #13 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by skyking View Post
I prefer the idea of a quieter, low drag direct drive. They do not have the same torque off the line, but I have legs for that. I can sprint pretty hard for a few strokes.
The demo ride today was a bit of a bust. They brought the bike up from another store and neglected to check the battery or plug it in.
It had 2 bars out of 5. I rode it around 40 minutes and killed it dead.
This is a 350 watt direct drive, quite a bit less than the one I am proposing to build. it does assist OK, but is pretty meager on straight motor. I don't care about that except as a measure of what it can do.
My ride in to work is primarily downhill, it is the trip home that would leave me sweaty.
If it was mostly depleted then the voltage and power were down too, so that's worth thinking about in terms of the power the motor could deliver.
If you go direct drive, get a motor controller and throttle that can do regen, then. You have long hills to work, so lots of your braking could be with regen during the commute in. Would be fun to see how well it works for you.
