Old 12-15-2008, 08:28 PM   #2 (permalink)
captainslug
Misanthropologist
captainslug's Avatar
BORK! - '89 240 DL Wagon
90 day: 21.27 mpg (US)
The system will have to use a pump if you want a decent thermal exchange rate. It won't need to be much of a flow rate though, so a low-power pump or even a hand-operated pump will do fine.
A hand-operated pump would make "crank up the heat" a rather literal command.
