Old 01-06-2009, 10:45 AM   #12 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
I may have been misunderstood...
That looks like a 3-phase electric motor. What I want to know is where the DC from all of those batteries is changed into AC for the motor. Is there an inverter within the controller, or is that a separate box? If so, there would be more expense to the system. Also, does an AC controller vary the voltage, or the pulse width like a DC controller, or cycles per second???
Where can I go to learn more about all this???
If a simple inverter could be designed, and someone like MPaul come up with a controller that wasn't too expensive, then I'm thinking that instead of going with a small car to convert, I might do an S-10 and have the batteries to get the voltage up to where it would be able to run at highway speeds - whether I use AC or DC. By looking at Wayland's Datsun stuff, either way can be great fun!
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
