Old 11-27-2007, 11:30 PM   #6 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
09-07-2006, 12:04 Am
STARTED OVER...
With coroplast. Front sections cut & installed.
Front portion of the undertray is in place & fastened. I got most of the center section done this evening too.
I - gasp - drilled holes in the underbody to fasten the coroplast. I think that's the real reason I've been procrastinating. I just feels so wrong to drill underneath - thinking of rust.
Once all the panels are in place, I'm going to do a B-A test, where I do some runs with the full tray, then remove it on the roadside and repeat the runs. I'm not doing A-B-A. Too complicated.
After the test, I'm going to have the car professionally undercoated and then put the panels back on.
The trickiest area left to do is the rear control arms. They hang down LOW into the flow - they're located about at the halfway point between the road and the bottom of the rear bumper. I'm thinking I may try to use the coroplast to extend them backwards in a teardrop shape. Complicated, but they're definitely a drag problem the way they are now, all blunt and exposed to the flow.
