Old 01-21-2015, 09:46 AM   #41 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
I've called dibs on both the truck and trailer, just need to get the paperwork sorted out.
While I'm dreading having to feed the truck's fuel addiction, it will be a good aero project after we get settled.
Camry Thread
E-Bike Thread
Old 01-21-2015, 01:26 PM   #42 (permalink)
90 day: 19.36 mpg (US)
You're already familiar with resealing the roof? Aware of marginal tires and suspension on most trailers? Etc. If it is a conventional hitch TT then the Pro Prde hitch is unmatched. Also, GMT700 hitch receivers on this era trucks are not at all adequate. Specify a Class V Draw Tite for installation. Also, DIRECLINK brake controller.
Michelin recommends wood under tires no matter the parking surface. I use 12" pressure treat cut to suit, with beveled ends. Tires can be overinflated 10% past sidewall maximum when parked. Tire covers are proven to extend life. I would replace any ST tire past three years of age.
A big truck trailer service shop can do the alignment, safety inspection and brake/bearing service. A Lippert shock absorber kit would also be good.
This is also the right time to replace breakaway switch and convert exterior lame to LED. Discover and service all issues having to do with road performance first. A lame TT is then no substitute for a tiny house given higher utility costs.
The mechanical issues of a combined rig take precedence over rolling resistance and aero resistance. Once sorted, one has an adequate set of numbers derived to make future changes. A poorly hitched combo will not provide a baseline for reporting.
Good luck. Look forward to your thread. I've posted elsewhere on travel trailers at length.
The Following User Says Thank You to slowmover For This Useful Post:
MobilOne (06-01-2015)
Old 01-21-2015, 03:38 PM   #43 (permalink)
vskid3's Avatar
I'm planning on resealing the roof as soon as possible. It doesn't look bad, but better safe than leaky. Tires are new. It comes with a Reese weight distribution hitch. My dad isn't a fan of them, but it'll do for now. The trailer is going to be stationary as much as possible. I don't see us putting more than a couple hundred miles on it in the next year and a half (the RV park we're planning on staying at has a stay length limit, so we'll go somewhere else for a week and then go back).
LED lighting will be one of the first upgrades. I want to see what I can do about adding insulation. Using coroplast to seal the belly between the frame rails and adding a little foam or Reflectix insulation (still researching them) should be easy. It would probably be very helpful to the AC if I could cover the roof with something reflective/shading.
I'll start separate threads for the truck and trailer (possibly on EcoRenovator) when I have them and start working.
Camry Thread
E-Bike Thread
Old 01-22-2015, 11:05 AM   #44 (permalink)
Prodex
Atlas Energyshield
freebeard (01-22-2015)
Old 01-22-2015, 01:25 PM   #45 (permalink)
What do you think about Snow Seal?
AmesŪ 5gal Snow Seal Roof Coating (SS5) - Roof / Foundation Coatings - Ace Hardware
Old 01-23-2015, 05:25 AM   #46 (permalink)
Ceramix is the last product I'm up on. But all aluminum trailer owners have to be somewhat careful about what works. Rivet seal, etc. conventional plastic trailers are plagued by a membrane roof due to wall structure moving unevenly.
That said, on a trailer like mine a modern white roof coating is worth 10-15F degrees interior heat reduction, both by report and that Airstream coats the roof on new models.
Eternabond tape is a universal.
The Following 2 Users Say Thank You to slowmover For This Useful Post:
freebeard (01-23-2015), MobilOne (06-01-2015)
Old 01-26-2015, 10:43 PM   #47 (permalink)
order99's Avatar
Sold my three bedroom, two bath house and acre of land last year, bought a 2006 Jayco 8'X30' travel trailer for 35% new (previous owner had damaged the roof and traded up rather than fix it, the dealership rebuilt the damage and recovered the roof). The trailer has no slideouts-the lack of standing space is more than made up for by the lack of seal maintenance and the sturdier (and lighter) construction. The trailer was listed as 'bunkhouse-style', which meant that there was a double bed in the bedroom, a couch that unfolded into a bed, a table that converts into a bed, and a single bed bunked above a double bed in the back...
Being blissfully single I decided I had too many beds, and since I had purchased the trailer used I had no compunctions about removing the master bed, turning the new space into a walk-in closet via the magic of a cedar dowel and a curtain, and using a small table and two bookshelves to create a computer/office/library. I then removed the mattress from the top bunk, sawed the bunk into a 'U'-shaped wraparound multimedia shelf and replaced the table-bench build with a collapsible breakfast nook with folding chairs...this leaves me with a cozy double bed complete with open ceiling, and a couch-bed for guests/emergencies, plus a nice, uncluttered floor for futons if the need arises.
I am very, very happy with my new(to me) home.
Now for the downsides...my usual 'Ecomodding' tricks will not work in a trailer. The walls are as insulated as they will ever get, although slipping in one inch thick foam board in the cargo pods helps a bit. The ceiling has room for more foam IF I drill holes every three feet or so and squirt it in-I may decide to do that this spring, but i'll have to repaint after plugging. I did screw some 1X2's to the bottom of the existing floor from below, create another sub-floor of varnished marine-grade ply between the wheels and inject lots of foam in the space between...I suspect i've added at least R12 or so to the R11-rated floor. I would like to insulate the water heater but it is a dual gas/electric so no-go on that, and the only way to insulate the inside piping is by prying up the couch and popping open the wheel well coverings...I may do that later this summer. My outside water and waste lines are wrapped with enough foam to be mistaken for HVAC ducts...also, the trailer is actually TOO watertight, and I need a dehumidifier in winter to keep things dry-I use a $3 disposable chemical absorber twice a month and let the AC take care of things in summer.
As I mentioned the Water Heater is dual-use, as is the fridge-the stove and internal heaters are both propane. I haven't used a single whiff of gas since I took ownership-I placed an oak cutting board over the stove and have a deluxe toaster oven there (easily as big as the oven below it) and I heat the entire place with a 1500 watt heating cube-I have never needed any of the higher settings on that heater to feel comfortable in the coldest day of the year (about 24 F in NC in February) and the AC is electric...despite the lack of insulation I am regulating a much smaller area, and as a result my biggest power bills to date have been $71 in the dead of winter and $46 at the height of summer. I have plenty of room for my belongings and have installed an 8X8 shed outside as a workshop.
If I move to a sunnier park with less shade in the future, a Solar Thermal panel hooked into my heating intake would work wonders in winter, and I would consider a second battery and PV panels to be essential. Right now though I am in an area with far too much shade for solar, and I don't see moving anytime soon-in fact I love this place so much I am pinned down and wheels off, and am paying yearly rent rather than monthly (YAY 43% DISCOUNT FOR YEARLY RATES!!!) and am happily building and selling guitars as part of my fledgling business venture.
If I am ever to the point where money allows, I intend to build a Tiny House of roughly the same proportions as the 8'X30' but with a (possibly more efficient) Ecomod redesign complete with removable composting toilet, and with a slightly smaller workshop/guesthouse connected by a roofed porch/walkway...and a patch of land one half-acre or less where the zoning laws permit me my construction eccentricities and a solar/wind bank with a battery house built into the small tower...might never happen, but who knows?
The Following 3 Users Say Thank You to order99 For This Useful Post:
Fat Charlie (01-28-2015), Insight for life (01-26-2015), vskid3 (02-01-2015)
Old 01-26-2015, 10:48 PM   #48 (permalink)
order99's Avatar
Ugh...Hope that massive wall of text I just posted wasn't TMI.
To summarize for those who don't want to drown in wordswordswords....I love Tiny Homes, got a Travel Trailer 'downgrade' and am happy with it after much cheap modding-that is all.
Old 02-01-2015, 12:45 PM   #49 (permalink)
vskid3's Avatar
Thanks, the paragraphs made it much easier to read than if it was a solid wall.
I would like to go propane-less like you (at least when on shore power). The biggest hurdle will probably be the water heater, which I believe is propane only. We'll have to see how much propane it ends up using and see if switching would be worth it. How do you like just using the toaster oven?
Waiting for the checks to arrive in the mail, then we can purchase the truck and trailer. Should have both purchased by the middle of the week. Gave our 30 days notice to be out of our house, so by March 2 we'll be living in the trailer.
Camry Thread
E-Bike Thread
Old 02-01-2015, 01:08 PM   #50 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
congrats! What will you do with all your cars lol?
