12-01-2016, 06:21 PM
PSmodder lurker
ICE dead, not so fast
The ancient opposed piston layout may come back and fight on.
The lighter, lesser friction surfaces and simpler design do not need the typical four-stroke engine valvetrain, intake and exhaust ports, and complexity of synchronized camshafts and valves.
Electronic control now allows the optimum metering of air and fuel precisely and could take advantage of the design's inherent simplicity and efficiencies.
Opposed-Piston - Achates
The Following User Says Thank You to botsapper For This Useful Post:
12-01-2016, 10:04 PM
They say about 4 years from being put in a car. Is this the Elio motor?
The Following User Says Thank You to Hersbird For This Useful Post:
12-01-2016, 11:23 PM
It would be interesting to see more technical data on the engine. It obviously has some benefits and I'm sure some drawbacks.
12-02-2016, 08:23 AM
"Simpler design" should have a disclaimer. It's interesting that you could possibly do away with camshafts, but without additional hardware you now have a fixed valve timing engine. I foresee most solutions to this being more complicated and potentially more failure prone than a balanced rotating shaft.
Plug-in hybrids (or EVs with "range extenders) are certainly one solution to battery limitations, but ICEs today are large and complicated, and take up a significant portion of a vehicle. Anything that can downsize the footprint without sacrificing efficiency would be great.
12-02-2016, 09:48 AM
The only 2 stroke engine I have seen that even have a shot at possibly meeting emissions in the US use exhaust valves.
12-02-2016, 10:15 AM
home of the odd vehicles
With direct injection and a cat you shouldn't need them, only issue is you would have to run "lean" to burn the oil blow by or have a trap of some sort
12-02-2016, 10:59 AM
Modern snow mobiles run oil injection separate from the fuel.
The exhaust valve engines appeared to allow for more power at full throttle and delay the exhaust rejection to allow more time for better fuel burn at part throttle.
12-02-2016, 11:21 AM
The part throttle or variable valve issues could be solved by teaming it with an electic propulsion and running the motor at max power just to recharge batteries. A setup like that should be allowed to have higher emissions while it's running because maybe it only needs to run 1/2 or 1/3 of the time.
12-02-2016, 12:12 PM
#10 (permalink)
PSmodder lurker
Different opposed piston engine designs
Opposed piston engine in a hybrid setup.
Another engineering group and their opposed piston/opposed cylinder setup.
Even weirder, a rotating opposed piston engine!
