Old 08-26-2020, 06:28 AM   #31 (permalink)
AdrianD's Avatar
it would be possible but I don't know if there would be benefit from the side plates being too far inward from the edge of the D-pillar:
Old 08-26-2020, 06:43 PM   #32 (permalink)
Maybe, even if the side plates get closer to the edge of the D-pillar, you could still make some attachment which would allow the entire spoiler to lift up with the rear hatch. How to get it supported by the rear glass might not seem easy, but I'm sure it's not rocket-science.
Old 09-09-2020, 07:32 AM   #33 (permalink)
AdrianD's Avatar
The front left wheel looked like it pointed way out compared to the right when the steering wheel was straight. So I rigged up a toe-measuring tool and it turns out there was a massive amount of toe-out, enough that I had to thread in the left side tie-rod 5/32".
Normal specs call for 1/16" toe-in on each side and by my measurements, toe-out was 5/16".
I've been driving like that for all the tests after the transfer case swap since almost at the same time I replaced the left side tie-rod.
Now I'm curious to see what effect that has on the fuel consumption reported by the trip computer.
The Following User Says Thank You to AdrianD For This Useful Post:
Ecky (09-09-2020)
Old 09-27-2020, 03:06 PM   #34 (permalink)
AdrianD's Avatar
I took the car for a professional alignment after my diy alignment:
0.005" of toe-out on the left side
0.04" of toe-out on the right side.
The guy at the shop said it's green on the machine and did not want to touch it any further. I'll build a couple of steel plates and then I can dial it in to a little bit of toe-in.
And we were lucky and managed to go on the summer vacation, which means fuel economy data.
I've had some sections identical to last year.
Section 1 (293 miles, 40 miles of highway, similar traffic):
25.59 mpg in 2019
27.22 mpg in 2020 - this is very close to what I noticed testing earlier
Section 2 (232 miles, 70 miles of highway, worse traffic in 2020):
28.51 mpg in 2019
27.47 mpg in 2020
Total average fuel consumption over the entire trip:
2051 miles / 25.34 mpg in 2019
1608 miles / 27.57 mpg in 2020 - this includes 2 hours of driving in torrential rain, and even more with very serious wind and 400 less highway miles.
This is a sample of national roads. Every time I'm driving under 40mph, the torque converter unlocks, so that's wasted fuel.
Driving in the torrential rain I must've hit a puddle fast enough to break the airdam away from one mounting bolt, so I will rebuild it out of sheet metal and I will have the option of adding a shelf on the bottom if that could reduce drag.
Total average fuel consumption over 11.250 miles: 23.9 MPG.
Ecky (09-28-2020)
Old 09-28-2020, 10:18 PM   #35 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
I take it that this did not give you a low range like the truck transfer cases?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 09-30-2020, 01:01 AM   #36 (permalink)
IIRC they still had a low range as standard.
Old 09-30-2020, 03:29 AM   #37 (permalink)
AdrianD's Avatar
It's still the same 2.72 low range as the old transfer case.
skyking (09-30-2020)
Old 12-27-2021, 07:24 AM   #38 (permalink)
AdrianD's Avatar
Not much happened in the past year car-wise, as having a baby that doesn't love sleeping in the car means all trips were under 90 minutes
However, in the idea of improving the rear aero, I have found the factory spoiler, which is said to reduce the dirt build-up on the rear glass. On rainy days the build-up is very severe.
Old 01-19-2022, 07:27 PM   #39 (permalink)
I remember similar spoilers used to be a quite common accessory for economy cars in my country, even though people got them mostly for the look than for the actual function.
Old 01-20-2022, 09:54 AM   #40 (permalink)
Odd side statement: way late into our travels, we found that my son was extremely sensitive to travel and got car/motion sick about 1/2 hour into trips unless he was sleeping.
