02-16-2015, 05:41 AM
#11 (permalink)
You can measure the voltage from the CTS that the ECU reads. It will be a nominally 0-5V signal wrt ground/earth.
If you want, you can calibrate sensor voltage against an actual temperature with the sensor removed from the engine or a junkyard sensor. Put it in water brought to the boil or cooling from boiling, with a thermometer to read the actual temperature. Then plot the temps with the corresponding voltage.
The sensor will need the ~5V reference, a resistor or two (see below) and ground to complete the circuit, but it doesn't have to be connected to the car. A USB from "12V" adaptor should work to provide the reference 5V voltage. I have bought cheap Chinese USB cables for $4 that are suitable to cut and make the connections to the sensor. I would not use a USB voltage sourced from a PC or similar device (in the interests of the device).
The caveat is that GM (usually) includes two pull up resistors inside the ECU in series with the CTS resistance. Two resistances - rather than one - are used to increase the resolution of the sensor by creating two V vs T curves/ramps. Above a particular temperature - about 50C - one of the resistors in the ECU is bypassed (a transistor is switched in the ECU to short around it).
When the sensor voltage is read with the sensor in the car, the two voltage vs temp. ramps/curves are: one for low temps, with the additional resistance, and one for higher temps, without the additional resistance. You should only be interested in the higher temps so don't really need the additional resistance other than to be aware of its existence.
In the GM ECUs for which I have info. the always-in-series resistance is 350 Ohms with the sometimes-in-series resistance being 4k Ohms. Those values may differ in other ECUs with other CTS. Measure the voltage between the "350" Ohm and CTS sensor resistances and ground. (You are doing this anyway if you measure the voltage signal in the car.)
If you do want to measure the voltage as seen in the car, you can use jumper wires to extend the wires at the CTS connector to reach the sensor that you are placing in the heating or cooling water. With the ignition keyed on the CTS voltage will be present and reflect the temp. of the sensor.
If the aim is to provide a visual indication of when the cooling fan or fans is or are active then the LED (OP) can be made to work.
It can be in parallel with either the switched or switching side of the relay that switches the fan you wish to monitor.
It does need a current limiting resistor in series with the LED. The value of the resistor depends on the particular LED you are using and its characteristics. A typical red LED might drop 2V across it and need to be limited to 30 milliAmps max. continuous current. Assuming that it will be fed from 14V (running car - charging alternator).
The resistor needs to drop:
14V-2V = 12V
Using V = I x R:
12 = 0.030 x R
Solve for R:
R = 400 Ohms.
So use 430 or 470 Ohms.
The Following 3 Users Say Thank You to Occasionally6 For This Useful Post:
02-16-2015, 09:20 PM
#12 (permalink)
What would you recommend for the voltage source? I might be able to get my hands on a DC power supply but there are no guarantees on that one. Any other ideas would be appreciated.
02-17-2015, 04:13 AM
#13 (permalink)
Watching my UG on the Acura, the cooling fan kicks on at 215 F, and stays on until temps drop to 195 F. The thermostat keeps temps around 188 F for the most part.
02-17-2015, 05:33 AM
#14 (permalink)
Why not just put a small current 12v bulb in parallel with the fan motor? Why make it complicated?
The Following User Says Thank You to MobilOne For This Useful Post:
02-17-2015, 06:19 AM
#15 (permalink)
That will tell you when the fan turns on and then a look at the scan gauge, if set to measure coolant temp, will tell you the temp that the fan is activated.
02-17-2015, 06:31 AM
#16 (permalink)
Chief - '06 Pontiac Grand Prix 90 day: 26.7 mpg (US) SF1 - '12 Ford Fiesta S 90 day: 30.95 mpg (US)
A USB phone charger outputs 5V.
Go here for pin layout.
https://en.wikipedia.org/wiki/USB
The Following User Says Thank You to nemo For This Useful Post:
02-17-2015, 10:26 AM
#17 (permalink)
does anyone know how well a "cylindrical radiator would work? Basically what i'm asking is if i got a couple different sizes of aluminium pipe from say 6-8"
all the way down to say 1.5"(being the size of the coolant line out of the radiator) pipe in 1" increments and put them inside one another, running a channel around them in a spiral front to back with added fins for cooling. would it give more cooling then the radiator or no?? i'm thinking that by cooling the coolant to a lower temperature can give far better temperature control then what they have now. I've measure a temperature difference of only about 30-40 degrees from the in to the out(and the coolant is only in the radiator for about 24") of a radiator on my jeep, so i'm thinking if you could double that it would be better.
so to summarize i'm talking about trying to run the area of a 1.5" pipe around 4-5 other pipes in order to increase the coolants over all time in the "radiator" from 24" to as high as 6-8' or more.
02-17-2015, 04:41 PM
#18 (permalink)
Unfortunately I do not have a scan gauge yet :/ The activation temperature light for me right now until I do purchase a scan gauge is just to be used as a reference to make sure my fan is not running, moreover to gauge how much grill block I can get away with. Judging by how cold it is currently I may be able to get away with a partial upper block.
02-17-2015, 05:41 PM
#19 (permalink)
Spaced out...
Do you have a non-apple smart phone? The torque app and a bluetooth OBDII dongle can get you started with data acquisition for less than $20...
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
02-17-2015, 06:45 PM
#20 (permalink)
I was just looking at the wireless connectors for the OBDII, it looks like I may pursue that route.
