Old 09-13-2022, 04:18 PM   #11 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Well, 30 year old carbon steel hinges didn't last that long. Two of them snapped off while I was opening the lid up.
I can definitely tell the weight difference (maybe 75lbs to 100lbs?) when driving around topless.
I've got some stainless steel angle brackets and stainless steel hinges coming in to fab out some replacements. The hardware fer this alone is about $80 (bolts, washers, nuts, hinges, brackets).
Name:	2012 Scion iQ with topless trailer hook up.jpg
ID:	32858   Click image for larger version
Name:	2012 Scion iQ with topless trailer side view.jpg
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (09-15-2022)
Old 09-13-2022, 04:29 PM   #12 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I might even be tempted to make a quick lightweight lid from some Foamular, a cargo net, and cargo straps vs putting the original lid back on.
Old 09-13-2022, 04:46 PM   #13 (permalink)
The frame is too wide at the back. Will you eventually cut-and-shut some taper into it?
"We're deeply sorry." -- Pfizer
Old 09-14-2022, 04:16 AM   #14 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I'm not looking to modify this frame. If I have enough resources and skill sets, I might look into building a custom single wheel frame that would incorporate the ideal shape fer an aerodynamic single wheel frame. I think the shape of the Allstate single wheel frame would be ideal as it's built that way.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (09-15-2022), freebeard (09-14-2022)
Old 09-14-2022, 04:23 AM   #15 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I had an opportunity to play with the height of the arm attachments today. I originally put them low (front is below level) as others have been saying this is the ideal position. I experienced "bucking" while driving at any speed. I raised the front 2" above (slightly above level) and the "bucking" is gone. I designed my attachment (made with 1/4" steel plate) to be totally adjustable in height so I can raise/lower it well above/below level as a test. While this may not work fer most single wheel trailers, it's been working fine fer this one.
Old 09-14-2022, 11:21 AM   #16 (permalink)
Want:
Now I'm looking differently toward my Westfallia.
BamZipPow (09-14-2022)
Old 09-14-2022, 01:34 PM   #17 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Want:
The problem is finding one fer sale that isn't so expensive that you'd be better off making one yerself.
The key is the swivel wheel system. This is the only company that makes one fer sale. Everyone else will not sell just the swivel wheel mechanism without the trailer.
https://crystalwelding.com/360-swivel-axle/
Old 09-14-2022, 02:48 PM   #18 (permalink)
At one time, I contemplated a 'floater' with a wheelie bar or skid for ground strikes.
Something like this:
Looking at that first picture today, I wonder if paneling in the bike rack would make a 'base plate' to substitute for the Kamm-back that would compromise engine cooling.
BamZipPow (09-15-2022)
Old 10-04-2022, 07:30 PM   #19 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Making a quick run to Arkansas and the chairs I need to bring won't fit with the lid on...so off comes the lid! I've also made a quick mudflap.
Name:	2022 trailer mud flap no lid.jpg
aerohead (10-06-2022)
Old 10-26-2022, 04:55 AM   #20 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Modified the adapter plates by notching them out fer clearance fer the front landing gear when going over a steep bump/hill. I figure about 4-5lbs cut out of the plates. The Diablo Steel Demon worked perfectly fer cutting the 1/4" plates! One shop wanted about $100 just to make the same cuts.
After dropping off the chairs in Arkansas, I had to transport a dining table and 6 chairs. The shop owner didn't think it would fit on top of the car and didn't figure I'd have a trailer hooked up to a small car.
I guess I could use the adapter plates as support/attachment points fer my side gap covers. I could even attempt a box cavity with those as well.
Name:	trailer adapter plates comparison.jpg
ID:	32965   Click image for larger version
Name:	trailer adapter plates cut.jpg
ID:	32966   Click image for larger version
Name:	trailer loaded.jpg
ID:	32967   Click image for larger version
Name:	circular saw and diablo steel demon.jpg
aerohead (10-28-2022)
