Go Back   EcoModder Forum > Superturnier's Profile > Albums
Plastic Spaceship
Fuel consumption per temperatue
Attach the heater and the mounting pad with screws to the gearbox.
There's heat conducting compund between the heater & pad
And excess amount of...
Fill the gaps with aluminium foil
This is where the heater is coming. Not very flat surface, as can be seen.
The mounting pad has been grinded a bit to fit better to the gearbox
Gearbox heater 300W and a selfmade mounting pad
Renault Espace
