Old 01-07-2012, 11:01 AM   #1 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Acrylic Paint removal from Plastic
I have some plastic which I mistakenly sprayed with black acrylic matt paint a couple of years ago. The plastic is the soft stuff models are made of - its actually a car model I was painting at the time. I need to remove the paint without damaging the plastic and removing detail so I can paint it correctly. I've tried oven cleaner which removed enamel paint without any issue but is not doing much for the acrylic.
Anyone any ideas what may be safe to use ?
No longer here. Bye, and good luck to all.
Old 01-07-2012, 05:45 PM   #2 (permalink)
You have two alternatives: solvents or abrasion.
The trick is to find which solvent will dissolve the paint without harming (melting) the plastic. I doubt that any solvent will work, as acrylic paint itself is related to plastic composition. Start with the least volatile solvents and progress to the more aggressive ones. Begin with naphtha (benzine). If it does nothing, try MEK (methyl ethyl ketone) or lacquer thinner, which is a blend of solvents. Don't try acetone alone, as it almost surely will wreck the plastic. Test cautiously in an inconspicuous area.
I'd wager that any solvent that dissolves the paint will also dissolve the plastic. The alternative is to use ultra fine sandpaper or rubbing compound (as a follow up) to wear the paint off through abrasion. If you are going to repaint the plastic it won't matter. But it's highly likely that removal of the existing paint will leave you with a dulled surface, no matter what you use.
The Following User Says Thank You to Thymeclock For This Useful Post:
Arragonis (01-08-2012)
Old 01-07-2012, 09:26 PM   #3 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
My same mistake yesterday. And the answer is sadly what I expected.
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 01-07-2012, 10:00 PM   #4 (permalink)
Ladogaboy - '011 Lancer EVO GSR
Team Emperor
90 day: 27.18 mpg (US)
E85 EVO - '011 Lancer EVO GSR
90 day: 21.38 mpg (US)
You could actually use something like Turtle Wax for this... enough elbow grease, and the paint should come off.
Old 01-08-2012, 02:04 AM   #5 (permalink)
Try a post on a dedicated modeling site such as Armorara or FineScale Modeler.
This must have happened to posters on some of those sites previously.
Peter.
The Following User Says Thank You to Peter7307 For This Useful Post:
Old 01-08-2012, 11:59 AM   #6 (permalink)
Arragonis's Avatar
Team m8
I tried this approach with a cutting paste but its a little too fiddly.
Thanks to all for the suggestions. I eventually went with a white plastic primer and then a quick run with the cutting compound once hard - that restored the colour and I could paint it again. It didn't fully match but the parts which are discoloured are underneath and inside, so it should be OK.
Old 01-09-2012, 08:59 AM   #7 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
In a past life I used to build models.
Acrylics should come off with oven cleaner though there are a few issues.
- Oven cleaner isn't what it used to be due to health regulations, it's now far weaker stuff and less suitable for paint removal (less caustic soda in there).
Put the parts in a plastic bag, spray, seal the bag, let it sit overnight.
- Caustic soda dissolved in hot water should do the trick - let it cool down to no more than lukewarm before putting the model in it, or the plastic will warp.
(Gloves, eye and breathing protection highly advised when handling and dissolving solid caustic soda ! From a former employment, I recall a delivery driver being hospitalized after getting a single chip of caustic soda in his shoe, he didn't realize it until hours after the delivery. Nasty stuff.)
- IPA or iso-propyl-alcohol is a good thinner for acrylics, soaking the model in IPA will weaken the old paint.
(Cover the container containing the IPA and model with something that seals it off or the IPA will evaporate quickly - not too healthy either.
Note : so-called rubbing alcohol may contain ether which will attack the plastic - check the ingredients before using on plastic.)
Lifetime fuel consumption :
The Following User Says Thank You to euromodder For This Useful Post:
Arragonis (01-09-2012)
Old 01-09-2012, 09:13 AM   #8 (permalink)
Arragonis's Avatar
Team m8
I tried the oven cleaner trick - that worked on the enamel paint and got the whole thing cleaner than it was before I started except for the part painted with Acrylics. It seemed to work on some parts but the rest would not move.
I'll take a look at the other options if I do it again.
Models is reasonable therapy when the gales are on. Now work has started again I can see this one going back on the shelf for another 12 months - I bought it in 2007...
Old 01-09-2012, 06:40 PM   #9 (permalink)
euromodder's Avatar
Diesel
Perfectly normal
