Old 07-09-2008, 06:59 PM   #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Alloy wheels + Metallic Tape = Aero Racing Disk
Hello -
Because I have alloys, snap-on racing disk wheel-covers are not an option for me. Here is my current OEM alloys :
Notice that the wheel has a very flat profile, the holes are "cut" into an already flat disk.
While wandering around the Pep-Boys for ideas, I noticed this :
This gave me an idea. I cut patterns over my wheel, cut the tape using the patterns, cleaned the wheel with rubbing alcohol, and stuck it on my wheel :
Benefits :
- 100% Reversible. Just peel it off.
- Since it's an alloy wheel, paint damage is a non-issue.
Problems :
- Easy to damage. I have to warn whoever is working on it because they could accidentally ruin it.
- Too shiny for my wheels. But I found this kind in the meantime :
It is also better because it is wider.
- Not appropriate for all alloys. I think alloys that are very "flat" like mine are best. I think the tape needs to be applied to flat surfaces in order to be able to "span the gaps". Also, the gaps should not be too big. If the flat part of the alloy is too thin, I think the tape won't hold on very well.
- The exposed back part of the tape is still sticky. But, I am not too worried about that because I figure brake dust will coat it soon enough.
I only did one wheel to see if it would hold up and/or peel. No problems for the last 3 weeks.
CarloSW2
American Solar Energy Society
Old 07-09-2008, 07:03 PM   #2 (permalink)
texanidiot25's Avatar
Formula - '96 Formula/Trans-Am
90 day: 19.31 mpg (US)
Your gonna get jokes about fake chrome wheels, but that is a neat idea.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 07-09-2008, 08:32 PM   #3 (permalink)
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
Neat! But why not cover up all the holes (leaving the valve exposed)?
Where did you pick up that Metal-Mend tape? That looks like what I need for my rims..
They are steel, but have tons of holes that need covering up..
Thanks,
Rich
Cheers,
Rich
Old 07-09-2008, 08:50 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Xringer -
The original tape I found was too narrow to cover the big hole easily, so I used that as an excuse to follow the "middle path". I don't worry about my brakes overheating, but I figured I would have an easy excuse if anyone asked me (Look, there are holes, now leave me alone!!!!!!). I also didn't want to put too much effort into it if the tape peeled off after only a few days.
Thanks,
Rich
Yup, I think they may work for you. You have more space to work with than me, except maybe where it curves into the wheel.
I found both kinds of tape at Pep-Boys/Kragen/AutoZone kinds of stores. I was just in different parts of the store each time. The non-shiny stuff is also cheaper, like $7. It would have been my first choice if I had seen it first.
CarloSW2
Old 07-10-2008, 12:07 AM   #5 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Looks very hybridesque
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 07-10-2008, 06:42 AM   #6 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
I like it! I think it is wise that you didn't cover all of the holes (at least until you try it for a while). It is quite likely that if you covered all of them, your brake temps would be higher, and you could see quicker brake wear.
Old 07-10-2008, 07:57 AM   #7 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
neat idea! personally i'd cut some plastic covers for each hole so the tape has some backing, your could make a template by placeing a sheet of paper over the hole and press in against the edges of the hole so they make a fold in the paper (like you might have done as a kid with a pencil and a coin). you may and up with a few different templates depending on the different hole shapes.
what you might also considder if you care about looks is have custom vinyl stickers made
in a big O or C shape (to account for the curve) that cover the whole rim .
we've had some precut white promo window stickers made for out youth house and they wheren't all that expensive... so provided you can get a good price this could be worthwile (especially if you compare the cost & effectiveness with real moondiscs... if you make a few spare ones any damaged ones can be replaced) and perhaps for a little extra cash you could have something printed on them... i'm thinking: a spiral (spread ecomodding trough hypno techniques), logo's (spread ecomodding trough advertiseing), or fake spokes (deny your true nature)
aerˇoˇdyˇnamˇics: the science of passing gass
*i can coast for miles and miles and miles*
Old 07-10-2008, 08:27 AM   #8 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Nice job. I like it too.
Old 03-02-2009, 01:59 PM   #9 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
Got updates on this?
How are they staying on? Did you make them all the way around?
Did you eventually cover the other holes? Any mpg difference?
Past Present Future?
Old 03-02-2009, 04:21 PM   #10 (permalink)
Mine are staying on. Kinda dirty and snow covered right now.
Of course my MPG goes to pot every time I use the roof racks..
Cheers,
Rich
Duct Tape for Aero Testing? cfg83 Aerodynamics 28 03-31-2011 05:10 PM
