Old 08-13-2010, 05:35 PM   #41 (permalink)
speeds
Originally Posted by dmac257 View Post
I am just trying to learn not criticize one way or another but I get no sense of speed from this picture. It is my understanding from reading in this forum that speed matters. This picture stops action so well there is almost no bluring of the background or the wheels.
My understanding is that at slow speeds there is less compression of the air in front, air moving around the vehicle will be moving slower, the air will remain attached easier, the air will be able to close behind the vehicle easier .. so less resistance and less drag.
Higher speed would mean higher compression of air in front, faster air flow around the vehicle, and air will be unable to combine behind the vehicle fast enough so detaches with drag behind car.
And my question is this: Is the ideal aero template different for different speeds? If so how do you determine the ideal template for a vehicle that will NEVER see 65mph but will normally be driven at 45mph tops?
Don
For the size and length of road vehicles,the drag coefficient is constant above 20-mph.
As to compressibility,air is considered an incompressible fluid below about 250-mph,as a vehicle would be entering transonic flow in ground-effect.
At really 'slow' speeds flow would actually be less stable and drag actually be higher on a velocity basis do to the weak laminar boundary layer.
As velocity increases to 20-mph,there is a transition to a turbulent boundary layer where momentum of the outer strata of air can be communicated into the boundary layer adjacent the body by violent mixing,increasing the energy near the boundary and allowing it to batter withstand the adverse pressure gradient which occurs downstream of the point of maximum velocity,effectively moving the separation point further back,reducing the wake,and drag.
The 'Template' would be good for anything over 20-mph,up to around 250-mph.
The 'template',at 80% length ( about all we can use due to ground clearance ) would produce a car of Cd 0.13.If you streamlined the wheels and tires like solar racers you could go towards Cd 0.10.
Of course,practicality must be weighed out.Personally,I would only consider the whole length in the context of a trailer with sealed gap.
Cd (12-18-2010)
Old 12-18-2010, 01:09 AM   #42 (permalink)
SwamiSalami's Avatar
2LT's Tank - '010 Element EX
That was intense. Awesome.
Old 12-19-2010, 07:29 AM   #43 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
If you go back to the Flowillustrator video you will notice the green transition layer thickens noticible as it goes down the rear of the Beetle.
This may not be full seperation, but is causing significant drag.
A full seperation from a trip edge (ie "Herod's Helper") will cause less drag even though there is more turbulance.
Turbulent seperation provides force at a small magnitude in many directions while a thickened transition layer provides a larger force over an increased area, half of the rear of the car.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 12-19-2010, 05:18 PM   #44 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Herod's Helper isn't a trip edge; it's a spoiler.
Some Thoughts on Aerodynamic Shapes 3-Wheeler Aerodynamics 68 04-14-2012 02:16 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
1951 Diesel Beetle ~~~ 40MPG Laurentiu The Lounge 3 07-23-2010 04:43 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Modern Rolls Royce Phantom vs Aerodynamic Coupe Unheard Aerodynamics 2 06-19-2009 10:19 PM
