Old 02-25-2012, 11:18 PM   #11 (permalink)
low&slow's Avatar
l&s' Jag - '00 Jaguar S-Type SE
90 day: 25.86 mpg (US)
l&s' Vision - '82 Yamaha Vision XZ550RJ
90 day: 59.92 mpg (US)
L&S' Greenaero Ninja 250 - '99 Kawasaki Ninja EX250F Ninja 250R
90 day: 97.24 mpg (US)
SilverAero Ninja 250 - '04 Kawasaki EX250 Ninja
90 day: 88.24 mpg (US)
The coroplast doesn't bend that well and is much better for straight panels. The sign paper is weather resistant, bends easily and is great for the curved portions of the structure. 1"x 3/4" wood lathe is light , rigid, easy to attach with glue and screws. I also used some bamboo for x-bracing and just hot-glued it into place. I tested the new tail today and it works great. The only modification I'll need to do is add another attachment from the tail structure to the MC frame as it as tipped downward slightly. I run another tank and see how much improvement there is with the new tail.
I'll post some pictures on my build thread. Let me know if you additional info.
Old 02-26-2012, 08:59 AM   #12 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Do you score it on the inside of the bend to make it bend better ?
Old 02-26-2012, 09:10 AM   #13 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
That's what I was thinking too. Use a dull knife to fold in the inner surface between each rib with a score mark. How long will Coroplast hold up to weather and sun? Does it expand and wrinkle in the sun?
Old 02-26-2012, 11:51 AM   #14 (permalink)
low&slow's Avatar
I use a heat gun for gentle bends in the coroplast. I would avoid scorng the coroplast as it would reduce its stiffness and strength. Thats why the coated sign paper iworks so well. The coroplast is very durable in the weather and can last for years, no problems with expansion, shrinking or wrinkling.
Old 02-29-2012, 10:14 AM   #15 (permalink)
sendler's Avatar
I played around with some coroplast last night. It can be bent in one direction but you have to actually slit between the ribs on the inside and it still tends to be uneven. Also, while I was washing off the dirt from the piece that has been kicking around in my garage, I noticed that it expands enough from spraying hot water on one side or the other to make it warp. Don't know if the sun would ever make it wrinkle but it seems like it could. Luckily, my local race car supply shop sells .025" aluminum in 3x8' sheets for a mere $19. So it looks like my tail will be shiny.
Old 02-29-2012, 11:04 AM   #16 (permalink)
Send a message via ICQ to Electictracer
I think aluminum sheeting is an often over looked medium to work with. It is strong, can be corrosion resistant, easy to cut and bent, and most importantly light. If it’s good enough for airplanes, it’s good enough for hyper milling vehicles. Compound curves are difficult without the tools and most importantly the experience to use them, but this is often easy to design around. You can probably build it completely out of sheeting if you do it right, with bulkheads.
Any way I’m biased so this might not be a very objective comment.
Old 03-01-2012, 09:33 AM   #17 (permalink)
sr185 bullet - '81 Yamaha SR185 streamliner
Team Streamliner
90 day: 96.35 mpg (US)
Sunny Colarado - '06 Chevrolet Colarado WT
90 day: 24.18 mpg (US)
cbr250s - '12 Honda cbr250
90 day: 115.29 mpg (US)
Aluminum sounds like a great idea. you might want to try going straight to the supplier for your sheeting though. They should have a "drop rack" where they sell the stuff with dings in it that they can't sell to companies, and it's really cheap, if they have what you are looking for that is.
Old 03-01-2012, 09:41 AM   #18 (permalink)
sendler's Avatar
$.75 per square foot. He is selling me .025 aluminum cheaper than plywood.
Old 03-01-2012, 11:54 AM   #19 (permalink)
Team Streamliner
That's really good. I guess you'd probably pay the same at the factory, but you are getting a slightly better product. He's really giving you a deal.
Old 03-01-2012, 05:14 PM   #20 (permalink)
I use cereal box cardboard to make 1/4 scale prototypes of compound shapes for fairings. This translates to 4mm coroplast full scale in stiffness. I use .015" Lexan for slot car bodies and it is quite flexible. Coating the aluminum with a coat of resin or plastic would help the denting somewhat. We use plywood laminated between aluminum or melamine for railcar panels. Check into paper model techniques for getting the shapes you want.
The Following User Says Thank You to Grant-53 For This Useful Post:
veloman (05-31-2016)
