Old 02-24-2010, 03:49 PM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
The Climate Machine (for demonstrations)
A while ago I attended a small talk on climate change, and since then I have had the following idea in my head: A lot of people don't believe that humans are responsible for climate change because it they don't see a direct action-reaction chain. It's hard to understand that a drought or flood in a far away region of the world could be caused by what's coming out of my tailpipe. People have been spewing nasty stuff into the atmosphere for generations and the world is still turning, so why should that change during my lifetime? For many people, just listening to theory and dry facts is too much, if you want them to remember something, they have to see it.
So I imagined a wheel with a handle. Only the handle isn't directly connected to the wheel, but has some sort of delay mechanism. When you start turning the handle, the wheel is motionless, then it barely starts to turn. After a while you slow down and stop turning the handle, but the wheel keeps spinning. In fact, it's still accelerating. You turn the handle backwards, but the wheel keeps spinning.
I can imagine using this prop when demonstrating how humans effect the climate: First humans pollute (turn the handle), with no noticeable difference (wheel barely moving). At some point we've added enough change to the (eco)system that the wheel keeps spinning, even if we stop or pedal backwards. If we stop before a certain point, then the wheel will gradually slow down, else it will accelerate until it flies apart. I believe the Earth is at the point when humans should slow down, maybe even stop pedalling.
In the near future I may have the chance to organize a few talks on climate change myself, and I'm thinking about constructing a working model of this "Climate Machine". What do you guys think? Will it help get the message through? Any ideas on how to actually build it?
I think the best bet would be to start with a bicycle's rear wheel in which the hub freewheels when not pedalling. But what about the delay mechanism? I thought about a spiral spring from an old clock to store energy. But will that be enough? Maybe a small brake so that the acceleration phase can be slowed down in the beginning. I'll add that I'd like this prop to be "travel size", not much larger than the wheel itself, and not heavier than 5kg (11lbs).
Thanks for any suggestions
Piwoslaw's Peugeot 307sw modding thread
Old 02-25-2010, 05:03 AM   #2 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
maybe a clutch fan type setup..delayed reaction with fluid...and handle a pump, or something like that.
I like the approach of your idea.
I gained a metaphor with welding steel...it is the earth after all.
some stuff is happening 3 years after initial welding..like the car is its own little panet. Take the poison away, and it does in fact heal. Ironically CO2 is a poison for steel sheets, it even alters signals, density, and that equals heat without temperature. they do not talk much of this is global warming either.
Why the Civic VX is a superior highway FE machine MetroMPG General Efficiency Discussion 9 10-10-2010 05:26 AM
Some Detailed Pics of the 'GM Lean Machine' Tilting Trike Coyote X General Efficiency Discussion 10 10-03-2009 02:02 PM
Machine Work, EV Parts Royal Fossil Fuel Free 0 06-17-2009 10:21 PM
Wisconsin Conservation Driver license plates bennelson EcoModding Central 9 09-04-2008 09:36 AM
Low faith in biofuels for climate DAN The Lounge 0 02-02-2008 12:01 AM
