Del Sol, Underbelly Pan
1/31/2012 Update on page 4, bellypan version 2.0
Xxxxxxxxcxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxx Black Coroplast for stealth http://i101.photobucket.com/albums/m...r/IMAG0347.jpg Before: http://i101.photobucket.com/albums/m...r/IMAG0349.jpg Work in Progress: http://i101.photobucket.com/albums/m...r/IMAG0351.jpg Filling up the gaps: http://i101.photobucket.com/albums/m...r/IMAG0352.jpg Driver side complete: http://i101.photobucket.com/albums/m...r/IMAG0354.jpg Next: passenger side, rear bumper |
Black looks all macho and whatnot, but white reflects heat better. Makes obvious any drips, leaks, or burns/distortions, handy to know about. Also makes it easier to see what you're doing while crawling under the car.
Near heat sources, you might consider application of aluminum foil tape (like duct tape, but stronger, costs about the same at hardware store). |
White reflect sunlight better but does white coroplast reflect infrared better than black??
I think black might last longer in UV which isnt an issue below the car. If you wanted a material that last longer and looks better than coroplast buy alumalite. Alot of people make splitters and sometimes undertrays for their expensive sports cars out of that. |
Updates: Passenger side, rear bumper
Passenger side: unscrew taps holding on the side skirt, this allows you to slide the coroplast in between the side skirt and body.
http://i101.photobucket.com/albums/m...IMAG0356-1.jpg There is also a small opening for the jack point where you can thread the coroplast up to hold it in place while you are screwing it in. http://i101.photobucket.com/albums/m...r/IMAG0359.jpg Closing the gaps on the rear bumper: http://i101.photobucket.com/albums/m...IMAG0368-1.jpg Finished Product, Rear bumper: http://i101.photobucket.com/albums/m...IMAG0366-1.jpg Mid-car, showing exhaust clearance: http://i101.photobucket.com/albums/m...IMAG0364-1.jpg View from the front: http://i101.photobucket.com/albums/m...IMAG0361-2.jpg Observations: did a preliminary quick run through my usual test spot, got 54.6mpgs (my previous run with current aero mods minus the belly pan 51mpg). will do a few more runs to get a more accurate reading. Oh, and the road noise has decreased immensely! |
Nice work! Where'd you get the coroplast, what thickness, and what did it set you back?
How did you fix the coroplast to the underside ?
I can see some tie-wraps - won't they tear into the coroplast when it vibrates during driving ? Do the screws go into the metal , or into other plastic fittings ? |
Looks like plain 4mm coroplast to me.
Does 10mm coroplast come in colors other than white or is that just my local sign supply shop?? |
Coroplast is 4mm Thick White cost's around $17ish per sheet, Black costs $20 per sheet...2 (4'x8') sheets = set me back $40 |
In terms of ripping, I was concerned about that, that's why I tried to make the hole from the zip tie closer towards the mass of the coroplast as possible (instead of near the edges where they could rip easier). |
