Old 12-07-2012, 07:20 PM   #11 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Dave,
Not to be a kill joy but how does winter diesel figure into your equation?
Old 12-08-2012, 01:23 PM   #12 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by ConnClark View Post
Dave,
I haven't accounted for it. For one thing I have no way of knowing what blend I get on any given fill.
Lots of people gripe about winter diesel killing their mileage. I'm of the opinion that winter itself makes much more of a difference than the winter diesel does. Summer diesel is pure #2 diesel. Winter diesel is often a blend of #1 & #2 diesel, with the blend depending on the time of year and the geographic location. #1 diesel does contain less energy per gallon than #2 does, however, if you look at the actual numbers, pure #1 diesel contains only about 4% less energy than pure #2 diesel. So if the blend were 50-50, that's only a 2% hit. So that's only going to make as much difference as a 4 deg F temperature change.
Also, I've read that additives are being used more and more to make winter diesel as opposed to blending with #1. I suspect this makes less difference int FE than blending.
I also keep a very detailed daily log. I've never been able to see any significant difference that's happened between tanks that might have been the result of fuel variation--so if there is a difference, I've never been able to see it.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 12-10-2012, 04:16 PM   #13 (permalink)
DieselMiser
ConnClark's Avatar
diesel number 2 BTUs a gallon 133,000
winter blend diesel number 2 BTUs a gallon 129,000
about 3.1%
At 30mpg a 3.33% difference is 1 mpg
Also you may not see a sharp jump due to mixing of the two blends at the gas station and distribution holding tanks.
