Old 12-11-2014, 08:29 PM   #1 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
Eco driving is good for brakes
Just measured the brake linings on my truck at 91,000 miles.
Front: Currently 6 mm remaining, 12 mm when new, wear limit is 1 mm.
Rear: Currently 3 mm remaining, 4.5 mm when new, wear limit is 1 mm.
Since I have three downhill full stops on my commute to work, and a few more downhill stops on weekends, I'd say that's not too bad.
The Following User Says Thank You to JRMichler For This Useful Post:
101Volts (12-29-2014)
Old 12-11-2014, 11:46 PM   #2 (permalink)
That is pretty good. My '94 still sports all the original brake pads and shoes. And BTW, the battery too! I've owned it since new and it would be an easy thing to compile the short list of every single component that's EVER been replaced or serviced.
Old 12-12-2014, 12:54 PM   #3 (permalink)
In general, yes it is good for brakes. But, too much of a good thing can lead to rusty brakes - so using them just enough to keep them healthy, but not so much as to wear them out too quickly.
Old 12-12-2014, 03:08 PM   #4 (permalink)
I hear that can be a hybrid problem.
Old 12-13-2014, 03:47 AM   #5 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Yep, I hardly ever use my brakes, even with the steepest hill out here (6% grade) I can maintain speed with regen only. In the city, brake usage is extremely moderate, most time slowing down is coasting or regen braking.
Old 12-13-2014, 04:02 AM   #6 (permalink)
Probably depends on your car too, the PO of my car only used half the original brake pads up in 12 years and 138k miles of driving, but having a <1 ton car helps a lot. Almost all my braking is engine braking so I have basically not used any of the pads up.
Old 12-13-2014, 06:43 AM   #7 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Since I installed the brake regen button in Turtle, I can literally go my entire commute without using the brakes! My front pads are at about half, and I may never need to change them no matter how long I own it. I never even plan on checking the shoes in the back since they outlast two or three sets of pads anyway.
When I press the regen button, not only does it slow the car by using the electric assist motor in regenerative mode, but the button also causes the brake lights to turn on, so my slowing doesn't surprise anybody behind me.
The Following User Says Thank You to cowmeat For This Useful Post:
user removed (12-13-2014)
Old 02-13-2015, 11:26 PM   #8 (permalink)
6th Gen Coupe - '02 Honda Accord EX 4 cyl
90 day: 28.01 mpg (US)
Zombie Accord - '98 Honda Accord EX
90 day: 24.71 mpg (US)
Ol' Red - '96 Ford F-150 XL
90 day: 14.43 mpg (US)
I agree, it helps with brake wear simply by conservation of momentum. I think it also is helping to extend the life of the transmission in my Honda Accord. I haven't done any sort of empirical study, but I'd estimate my driving habits eliminate greater than 50% of the 1-2-3 shifts. Car has 260k on it, but I unfortunately don't know if it is on the original transmission or not. Would be cool if it was though.
Old 02-14-2015, 08:07 AM   #9 (permalink)
90 day: 19.36 mpg (US)
Truck in sig
1 brake re line still at 50%+
Original clutch
Second set replacement tires recent
New ujoints and HVAC fan only repairs
Stays at 1k over factory weight
Tire wear is pretty much the overall easy marker for vehicle component life and mpg, IMO.
Old 02-14-2015, 07:17 PM   #10 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Problem with never using your brakes is they may not work when you really need them.
In my old MB100 I was slightly surprised by an ambulance at a cross road (you can't hear the sirens in modern cars anymore), I went for the brakes and wasn't too impressed with the lack of braking power. The brakes were in good condiition having recently (but not too recently) had new pads/ discs/ sliders lubed/ fluid.
Since then I've tried to give the brakes an occasional heavy workout when a stop is unavoidable anyway. Even so my new Renault still squeals a lot suggesting glazed pads and discs.
